Splice in X-Pipe???
  • Thread starter Thread starter jakef7
  • Start date Start date Mar 7, 2011
J
jakef7
44
Texas
Mar 7, 2011
  • Mar 7, 2011
Hey guys just installed the Pypes Pype Bomb exhaust today. Sounds great but I was looking for a little different sound. I would like the exhaust note to be a little higher pitch and not so deep. I was looking on Brenspeed.com and I saw that they sold a Pypes splice in X-Pipe. (I have to keep the cats on) Do you guys think it would change the exhaust note a little?
M
MyGG
60
Indiana
Mar 7, 2011
  • Mar 7, 2011
From what I understand, Yes. An x-pipe usually causes a slightly higher, raspier note than the h-pipe, and can lessen drone in some cases. If you don't care about cutting into your stock pipe, then this is the way to go. Plus, you should gain a couple hp from the improved flow. There's a youtube video of a guy with a 2010 and x-pipe with Pype Bomb, check it out.
J
jakef7
44
Texas
Mar 7, 2011
  • Mar 7, 2011
Hey man I really appreciate the response. I think I will give it a try. Its only $115 so its not like Im going to lose a lot if I decide I don't like it. Thanks again. If anyone else has any input feel free.
SkyRender
93
Frederick, MD
Mar 7, 2011
  • Mar 7, 2011
Just get the BBK X-pipe, which simply replaces your stock H-pipe. It doesn't require splicing (only 4 clamps), and it isn't much more expensive.
arcwcb
417
Pennsylvania
Mar 7, 2011
  • Mar 7, 2011
Does that include cats? Because the OP stated he has to keep the cats.
J
jakef7
44
Texas
Mar 7, 2011
  • Mar 7, 2011
Hey skyrender, I cant find the x-pipe your talking about? Is it an off road x or can I keep my cats?
SkyRender
93
Frederick, MD
Mar 7, 2011
  • Mar 7, 2011
Yes, you keep your stock cats. It only replaces the H-pipe and clamps on behind the stock catalytic converters. This is probably the next mod I'm doing on my '11 GT.
BBK, for a 2011 GT: BBK Performance 1460 - BBK Performance H-Pipes, X-Pipes & Merge Pipes - Overview - SummitRacing.com
MagnaFlow, for a 2011 GT: MagnaFlow 16398 - MagnaFlow Tru-X Stainless Steel Crossover Pipes - Overview - SummitRacing.com
MagnaFlow, For a 2005-9 GT: MagnaFlow 15485 - MagnaFlow Tru-X Stainless Steel Crossover Pipes - Overview - SummitRacing.com
J
jakef7
44
Texas
Mar 7, 2011
  • Mar 7, 2011
How much of a difference in sound are we looking at here? Ive heard going to an x-pipe will make you lose low end torque. Is this true?
gmantheman
483
Escondido, CA
Mar 7, 2011
  • Mar 7, 2011
The splice in X may not make that much of a difference. Here is video comparing stock h and slp lm with a splice in x and slp lm. I can't hear that much of difference. If you want a catted x, then get on that includes the cats. BBK, Pypes, magnflow, bassani, and slp make them. New these set-ups are $380 to about 450.
http://www.youtube.com/watch?v=OvBjesPpNT0&feature=channel_video_title
astronut1885
1,899
Assonet, MA
Mar 8, 2011
#10
  • Mar 8, 2011
  • #10
I've looked into this, and it seems pretty much it's a sound thing. Since the cats are the same, I don't think you will gain anything in performance, and the factory tubes are plenty big to already not offer restriction, but I have heard you get a bit higher and raspier tone. I am considering doing the same mod to get rid of some of the highway drone on my car, and its something you can do right in the driveway.
J
jakef7
44
Texas
Mar 8, 2011
#11
  • Mar 8, 2011
  • #11
I'm considering doing it just to see what it sounds like. The Pype Bomb axle back sounds really aggressive and it has that low growl which I really like. But on the other hand I think it's a little too deep for my taste. It does drone quite a bit at lower speeds but I really don't mind it because my car isn't a daily driver. I've read some reviews on the splice in x pipe off of Brenspeed.com and everyone seems to really like the sound of it. One review stated they could feel a small HP increase.
SkyRender
93
Frederick, MD
Mar 8, 2011
#12
  • Mar 8, 2011
  • #12
An x-pipe will give you better high RPM flow, will help eliminate resonance ("droning"), and shouldn't make much of a difference at low RPMs.
J
jakef7
44
Texas
Mar 8, 2011
#13
  • Mar 8, 2011
  • #13
I'm going to give it a try. It will only cost $200 total installed. I would like to get rid of some of the drone. The drone that I have now makes things buzz inside the car at low RPM sometimes. It kinda bothers me. Maybe the x pipe will fix that. Plus I might pick up a few HP. I just hope it sounds good. I don't want to lose that aggressive growl that it has now.
J
jakef7
44
Texas
Mar 8, 2011
#14
  • Mar 8, 2011
  • #14
Hey ya'll I was looking on americanmuscle.com and I saw that FRPP made a cut and clamp x-pipe too. It looks totally different than the Pypes cut and clamp x. Anybody have a suggestion or some input???
SkyRender
93
Frederick, MD
Mar 8, 2011
#15
  • Mar 8, 2011
  • #15
You want an X-pipe like BBK's or Corsa's. This is known as a "siamesed" x-pipe and provides better flow characteristics.
J
jakef7
44
Texas
Mar 8, 2011
#16
  • Mar 8, 2011
  • #16
I checked out the bbk and it looks the same as the pypes to me. What's the difference?
gmantheman
483
Escondido, CA
Mar 8, 2011
#17
  • Mar 8, 2011
  • #17
Pypes x-pipe design is ideal for flow. I do have the pypes catted X and I had one of the best exhaust shops in San Diego county do the install. Yes, I have done a mid-pipe install before but the pypes involved cutting and I wanted the cats welded on. The owner, Ed Hanson is one of the pioneers of the X-pipe. He said the pypes x-pipe design is an ideal design.
astronut1885
1,899
Assonet, MA
Mar 9, 2011
#18
  • Mar 9, 2011
  • #18
FRPP looks the same minus that little plate welded over the pipe union. I personally plan on going with whatever is cheapest as down the line I'm getting LTs and a Prochamber anyway.
L
Exhaust 95 gt pypes catted x pipe
  • Lx5.0fiend
  • Aug 22, 2025
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Sep 18, 2025
revhead347
L
Is catback worth it over axle backs?
  • Lorencarson
  • May 15, 2025
2005 - 2014 S-197 Mustang -General/Talk- May 15, 2025
89ripper
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
Salvage/rebuilt title question
  • djj62478
  • Oct 2, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 2, 2026
DadLife0724
Fox BBK X-pipe replacement Cat?
  • TIGGER
  • Aug 26, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 26, 2025
AeroCoupe
