Spring is here (Flex-A-Form)
IMACHU2
28
Here is a link to the Fiberglass leaf springs I was blabbin' about in my last thread. The springs only weight 8 pounds each and they can be custom ordered for size and spring rate. Kool with a capital "K". :D
http://flex-a-form.com/products.asp
I wonder if I stuffed some 15" Toyo RA1's on my mach how close the slalom and skid pad numbers would be to that dudes car in the mag?? I know the hockey puck hard 205/60R13 Cooper Cobras and 235/50R13 BFG T/A's are not up to it:lol: My II handles really well on the poly bushings and rebuilt suspension, but I would think those fancy rear springs must really work good to record those handling numbers:shrug:
Camshaft78 said:
Are these a viable option for a street-driven car? If so, I maight have a tough choice to make between these and the Racer Walsh lowering springs...
Can't say on these exact springs, but Corvettes have been running fibreglass leaf springs for over 25 years...
The stock springs that I have (76 cobra II V8) weigh 26lbs. The flex-a-forms really weigh 8lbs. I know its crazy, but they do. I think they are made of a combination of carbonfiber. I really should put some traction bars, but they have handled the abuse of racing and I drive it about 3-4 times a week to work.
I dare you to try.
Alcino Dare eh??:D Fiberglass leaf springs ar also used on the rear of GM's larger sedans (Olds delta 98, some Caddy's ect .) Interestingly the new Caddy has fiberglass springs front and rear that span the car horizontally. Wish I retained non-automotive information:shrug:
I spend time on SyTy forums (I know not a Ford but :hail2: )
Some of those guys use Flex-A-Forms too. Seems they react faster then steel leafs and control wheel hop for a better 60ft. But they are expensive. Some people do complain about a rough ride though. Any comments on the ride quality Alcino? Not that any of us that want performance care about ride quality.
what does rough mean? seams normal for how much stiffer it the spring is compared to stock. I think I paid $450 shipped. Is that expensive? Seemed like a good deal for the weight savings and that it was a part actually available for a ii. I've liked mine so far.
Blue Thunder said:
Rough means you p**s blood for a couple days after the ride.
I only found one person complain that bad, probably just a whiner.
I would expect them to be a bit harsher but I wouldn't care. Considering your changing from 30 year old worn parts to new, I hope there is a difference.
As for the expense. Lots of people would consider this extravigant (sp?), but it sounds good to me.
