spring question
02_2VStang
73
Cary, N.C.
what kind of springs would give my car alittle stance, right now i have just cut my springs, the car sits level, looks pretty good IMO. but i sorta want my car alittle higher in the back and maybe alittle lower in the front. any suggestions?
also what would be a good cam to run and now have to worry about inspection and stuff, and see some pretty good gains out of it?
thanks josh
what are the intentions of your car? dragging? or just daily driver with occasional track days?
take that back. i'm going to assume you're a daily driver. H&R Sports should do you fine. Eventually you'll have to change your struts and shocks.
As for cams, VT engines has good n/a stage 1 cams that'll pass smog and comp cams does as well. Make sure you get a good tune after.
