  • SN95 4.6L Mustang Tech
Spun Bearing, when does it "Knock"
  • Thread starter Thread starter Rickyll7
  • Start date Start date Sep 23, 2006
1 of 2 Next Last
Rickyll7
718
  • Sep 23, 2006
If you spin a bearing, when does it knock? Does it only do it when the engine warms up? Or will it knock all the time. what about engine speed? Will it get louder with engine speed, or will it only do it at an idle?
03ghoststang
Well-Known Member
Jul 16, 2005
1,930
Los Angeles, California
Sep 23, 2006
  • Sep 23, 2006
it will knock from start up till you shut it off and anywhere in between
Rickyll7
718
  • Sep 23, 2006
so you saying it will constantly knock? or are you saying it could knock at any time?
Dope 97GT
439
Rochester, NY (SUNY Brockport)
Sep 23, 2006
  • Sep 23, 2006
i believe it will knock the whole time...my friend did it twice in his GTP...and it knocked the whole time
Y
Yellow2002GT
148
Raeford, NC/ FT Bragg
Sep 23, 2006
  • Sep 23, 2006
The modular engines are pretty noisy in stock form....at start up on older engines you will get some ticking/knock from the front chain tensioners due to wear over time but will stop or barely hear them when the engine is warm......if your engine ticks from start up and ticks match the rpm of the engine....good chances it is a bearing or somthing in the valve train thats not right!
"ED"
Rickyll7
718
  • Sep 23, 2006
i cracked one of my headers recently, i can hear, smell, and feel the hot exhaust leaking. I think this is whats causeing the noise. my headers are wrapped and i think it is the two cracked peices hitting each other. the headers probably cracked because they got too hot with the header wrap. it only does it when hot, and is a random knock, not consistent with rpms. and it only does it at an idle, when the engine is rocking back and fourth from my cams BTW, It runs like a champ!
Sound about right? or is there another possible cause?
edit: note that there are two noices, one is the exhaust leaking through the wrap, the other is the strange knocking noise.
Rickyll7
718
  • Sep 23, 2006
Does anyone have an oppinion about this?
jasonh_86
I
May 20, 2005
1,156
Arkansas
Sep 23, 2006
  • Sep 23, 2006
http://www.youtube.com/watch?v=eKVhmUytZu8
Here's a vid of my recently spun bearing
Rickyll7
718
  • Sep 23, 2006
wow, very sorry to hear that. but glad to hear that that is not what i have. i think i might be right about the cracked header clanking
Y
Yellow2002GT
148
Sep 23, 2006
#10
  • Sep 23, 2006
  • #10
Yep....! Thats what a spun bearing sounds like! Sorry to hear that.....
"ED"
Mike97gt
it doe snot
10,633
the people's republic of massachusetts
Sep 23, 2006
#11
  • Sep 23, 2006
  • #11
Thats a spun bearing/rod knock noise. plus if you have a real oil presure gauge you will see the presure is jumping all over the place.
jasonh_86
I
May 20, 2005
1,156
Arkansas
Sep 24, 2006
#12
  • Sep 24, 2006
  • #12
Damn... I wish you could've heard it in person, man. It sounded 1000000x's worse and hurt so bad to hear
Luckily it has been laid to rest. The new motor is on it's way to the shop, altho it's just another '02 GT motor.. This one has 33k miles, instead of my 73k mile motor.
tomustang
Psychotic Member
3,434
McLean Hospital
Sep 24, 2006
#13
  • Sep 24, 2006
  • #13
and this is comming from your SHM stroker?
Rickyll7
718
#14
  • Sep 24, 2006
  • #14
Uh, yea. Have any ideas?
BTW, it sounds nothing like the video in here.
tomustang
Psychotic Member
3,434
McLean Hospital
Sep 24, 2006
#15
  • Sep 24, 2006
  • #15
spun bearing sounds are never the same, sometimes they are consistant, and others they are heard above idle and not under load, sound is like a hammer tapping on a block of aluminum, I defiantely know your block was prone to that since shm has 17yr olds fresh out of highschool vo-tech buiding engines
Rickyll7
718
#16
  • Sep 24, 2006
  • #16
Wow, I didnt know that. Well this is what it does...
random, (not consistent with rpms as in the video)
only at idle
but will usually not do it until it is warmed up
not loud at all like the video
about 1-2 seconds in between knocks
engine runs perfectly and strong
98armygt
33
#17
  • Oct 23, 2006
  • #17
i think i got a spun bearing as well. i thought it was valve train related but i went through it like 3 times. i did find little metal shavings or flakes in the oil pan. rod or crank bearing?? it doesnt sound like jasonh_86's car but close to it. its not as loud but when i give it cas i really hear it. around 1500-2000 all the way up. it didnt start doing it at idle till i drove it for a little bit. but now when it warms up it ticks or clacks or however it sounds.
the98stang
2,408
Clovis, CA
Oct 23, 2006
#18
  • Oct 23, 2006
  • #18
metal in the oil = no bueno
If I were you I would drop the pan and look at the damage. Chances are your rods are fried though if it's already knocking. Time for a MMR900 shortblock or VT
98armygt
33
#19
  • Oct 25, 2006
  • #19
i didnt notice the metal till i dropped the oil pan and it looked like someone threw confetti in there. i know i **** the bearings in that thing. so im gonna tear it down and start rebuilding back with stock parts. i plan on ordering a new short block from VT or MM come january to put back in the car. ill save the stock block just in case i break something else in the new one.
jasonh_86
I
May 20, 2005
1,156
Arkansas
Oct 25, 2006
#20
  • Oct 25, 2006
  • #20
Turns out mine was a busted valve guide.. there was metal all in my motor tho
1 of 2 Next Last
2001 SVT Cobra slow return to idle speed
  • phil2001svt
  • Oct 21, 2026
  • SVT Tech Forum
SVT Tech Forum Nov 2, 2026
phil2001svt
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
A
Rough idle - cylinder 1 and 6 misfire HELP
  • austindavies935
  • Jul 24, 2025
SN95 4.6L Mustang Tech Jul 24, 2025
gkomo
01 GT KNOCK AND NO IDLE FIXED!!
  • Scwhitten
  • Apr 27, 2025
SN95 4.6L Mustang Tech Apr 27, 2025
Scwhitten
Help! Fox with idle issues
  • bbarton
  • Sep 11, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 12, 2026
AeroCoupe
