sputtering and misssing
  • Thread starter Thread starter blk92
  • Start date Start date Mar 28, 2004
blk92
55
  • Mar 28, 2004
it will run fine for a min then i will stop at a light and it will miss and sputter at part throttle if i floor it it will clear up.
i have replaced the pcv valve, spark plugs, wires, cap and rotor,checked timming, fuel pump, fuel pressure reg. cannot fique out the problemshould i change the 02 sensors they have 115000miles on them or will a custom burned chio from murrillo motorsports clear it up
R
racerraj
493
32
39
Dickson, TN
Mar 29, 2004
  • Mar 29, 2004
Bump, I'd like an answer too.
N
noslow5_0
422
dallas tx.
Mar 29, 2004
  • Mar 29, 2004
it could be a bunch of things.... timing, vacuum leak, running lean... do you have an afpr??? if so, try to richen it up some... run the codes, to see whats going on...
N
noslow5_0
422
dallas tx.
Mar 29, 2004
  • Mar 29, 2004
oh and have you set or messed with the throttle stop screw or tps??? also how old is you IAC???
blk92
55
  • Mar 29, 2004
the iac has never been replaced when i unplug it it runs a little better
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Mar 30, 2004
  • Mar 30, 2004
Dump the codes and see what the computer says is wrong…
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great.
See http://www.troublecodes.net/Ford/
OR
See http://www.dalidesign.com/hbook/eectest.html for more descriptive help
OR
See http://www.mustangworks.com/articles/electronics/eec-iv_codes.html
Engine Rough idle and aggressive sputtering when accelerating
  • 88vertible
  • Aug 13, 2025
Fox 5.0 Mustang Tech Dec 13, 2025
Jarhead67
J
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
D
Running both lean and rich with O2 heat codes
  • Danceswithfire5
  • Aug 30, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Sep 5, 2026
apple99Mustangdude
A
Fuel ‘88 GT Runs Rich Cold — Fixes Itself When I Unplug Sensors (ECT, MAF, O2, etc.)
  • Sufarry
  • Nov 6, 2025
Fox 5.0 Mustang Tech Nov 9, 2025
Mustang5L5
G
Sputtering/misfiring below 2500rpm
  • Godless
  • Sep 14, 2025
2005 - 2014 S-197 Mustang -General/Talk- Sep 14, 2025
gkomo
