Sputtering-like sound at low RPMs
Javi
28
Houston, TX, USA
Hey, all. I've recently had some issues with my 2001 GT. Over the weekend, I noticed that there is a noticable sputtering sound in 1st-3rd gears at low RPMs. I felt like I lost a bit of power, so I did some research on here and replaced the fuel filter, and just this morning, replaced the spark plugs.
I then took it out for a test drive, and the sputtering sound is still there! OMGWTFBBQ! The power seems fine now, but the sound seems a bit louder (maybe I was almost expecting it to be loud). It does go away at the higher RPMs, only to return when I go back into 1st-3rd gears at low RPMs.
I dunno if this is related, but I've always gotten a sort of sputtering sound when I went into reverse. It's the exact same sound as my problem above.
Any ideas here? While I can do maintenance and repair, I suck at diagnosing problems.
Where are the O2 sensors? (yes, I suck).
Update: after a drive to work (20 miles, approx.), the sputtering sound seems to have died down a bit - No longer applies in 1st gear, faint in 2nd, noticable in 3rd and 5th gears.
o2 sensors are located near on your midpipe. There are two near your headers and two near you catback. It sounds like an exhaust problem to me since you have no loss in power.
Dude i'm having the same problem. it's a misfire from the coil on plug ignition. Every time i wash out my engine bay, water gets into the plugs and misfires when you put a load on it. Does yours do it at low rpm and when you give it more throttle? If so that could be your problem.
