- Jan 21, 2009
- 2
- 0
- 0
Hi,
I have a 2000 GT and ive had it for about a month and last week i was driving it and i pulled out of a parking lot and it started to spit and sputter a little and the entire way home it did this in every gear all over the rpm range. However it was worse in the lower range up to about 2000 rpms. When you get on it its not as bad in the upper but you can feel the power come and go. So i put new autolite plugs in it either platinum or double platinum not sure which, and a new fuel filter and those two things helped but it still did it. Then i bought some seafoam for the gas and put about a half tank in it to fill it up and the spitting and sputtering went away for a bit but then came back. I have no idea what it could be the service engine light isnt on. I tried unpluging the mass air flow but that didnt change anything didnt make the SEL come on. So im basically lost does anyone have any ideas? could it be coil packs, or tps thats going or is bad, mass airflow sensor bad? please let me know if you have any suggestions
Thanks,
Nathan
Thanks,
Nathan
