Squeak in rear suspension of 1997 GT convertible
oregon97gt
15
Salem, OR
Pretty much at any speed going over any size of bump there is a squeak in the rear suspension. It started a few weeks ago, and is starting to get worse. Sometimes even when I'm driving on flat pavement there is a slight squeak.
Any ideas what it is/how much it will be to fix?
The isolators are a rubber donut that sits on top of the spring, and one under the base of the spring. Depending on your rims, you might just be able too look in and see if they're there. If not, remove a wheel and check.
I'm asking does the squeaking stop when you hit the break pedal?
Hey man, I have a 96 GT very and mine squeaks while i am driving 90% of the time and when I brake it goes away. I just replaced the rotors and pads earlier this year and it is worse now than before. They were stock replacement rotors and pads. Any ideas on if its something other than a glaze on the rotors or how to fix? Thanks
