squeak only when wheels are turned left.
  • Thread starter Thread starter Foxfan88
  • Start date Start date Aug 17, 2005
Foxfan88
My Grandpa has great wood.
Sep 13, 2004
2,487
Miami, Ok
Aug 17, 2005
  • Aug 17, 2005
They squeak when i have the wheels turn left, i think its brake related since when i press the brakes it wopnt do it. What is it exactly??
CBZGT50
171
St Louis area
Aug 17, 2005
  • Aug 17, 2005
Sounds like dry wheel bearings to me. Pull the hub apart and grease those babies up. Then see if it still does it (squeek).
Foxfan88
Sep 13, 2004
2,487
Miami, Ok
Aug 17, 2005
  • Aug 17, 2005
we changed rotors like less than a 1000 miles ago. My dad packed em real good. So that cant be it. It never did it until the new rotors and pads....
CBZGT50
171
St Louis area
Aug 17, 2005
  • Aug 17, 2005
Then your problem can only lie in the pads dragging because of a hanging caliper. Spray a good amount of brake cleaner on the slider pins as you work the caliper back and fourth (not much movement). If you really want to get dirty, lube the pins with the caliper off. I have had hanging calipers on half my freakin cars. That lubrication of the pins is just maintenence. For sure!
Euphoric306
905
  • Aug 17, 2005
i woulda replaced wheels bearings while the hub was a part... my education was to never reuse bearings that have been in for a while, but thats just me
yea probably just plain old brake noise dude, they sell some stuff at the parts store to get rid of it
Mavrick
2,264
Collingwood, ON
Aug 17, 2005
  • Aug 17, 2005
Lube the sliders with anti-seize...
J
Suspension Foxbody mustang Steering shaft issue
  • Jakub2537
  • Sep 5, 2026
Fox 5.0 Mustang Tech Sep 11, 2026
gkomo
  • Mindseye007
  • Aug 16, 2026
Mindseye007
Brakes FOX BRAKES ISSUES
  • PonyGTrider
  • Jan 11, 2026
  • 2 3
3K
Fox 5.0 Mustang Tech Jan 31, 2026
Mustang5L5
D
rpm goes up - car does not speed up.
  • dawakbar
  • Oct 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 27, 2026
nickyb
I
Innova scanner not working 88 5.0
  • Idkwhatimdoing
  • Jul 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 23, 2026
Steverino
