  • SVT Tech Forum
Squeak!
  • Thread starter Thread starter jpbaker22
  • Start date Start date May 4, 2005
J
jpbaker22
185
Missouri
May 4, 2005
  • May 4, 2005
Well, the cobra is running again after a new fuel pump, but now I have this squeak comming from the engine. *sigh*
It only does it after it runs for about 15 minutes and it is spaced about a have second apart.
This is the 2nd belt i have put on this car. Original was covered in antifreeze from a cooling system flush from Jiffy Lube (don't ask), 1st one started squeeking about 3 months later, tried conditioner, brake ckeaner, wire brush, so i replaced it. Now this one has been on for about a year , but i only drove it for about 6 months out of that year. I put it on at the same time i changed the pullies.
What could be causing this? think i need to change out the tensioner?
PS The 1st replacement belt was advance auto, the 2nd belt was autozone.
01 Cobra
29
Macon,Ga
May 4, 2005
  • May 4, 2005
Change The Tensioner And A Gatorback Belt.
J
jpbaker22
185
Missouri
May 5, 2005
  • May 5, 2005
any reccomendations on where to get the parts. i dont want to do this again in a year.
ShakeandBake
40
Morgantown PA
May 5, 2005
  • May 5, 2005
I replaced my tensior with one from Autozone(50 dollars) and has held up fine. Also using a Dayco belt that is similar to the goodyear gatorback and is very quiet.
Sandman3022
138
North Georgia
May 5, 2005
  • May 5, 2005
Sounds like the bearings in your tensioner pulley are going bad.
J
jpbaker22
185
Missouri
May 6, 2005
  • May 6, 2005
latest status.....
i turned onthe a/c and the squeek went away. ilet it run for about 5mins then turned it off and still no squeak. fired her up this morn....squeak. still think its the tensioner?
Sandman3022
138
North Georgia
May 6, 2005
  • May 6, 2005
It's difficult to diagnosis a problem on a forum. Could be the bearings in the a/c pulley. My wife's GT is doing the same thing. First, it was real bad. Same thing with the a/c. Turn on the air and it went away. Came back the very next day. Changed the tensioner pulley. No more squeak for a while. Now it came back with a slight squeak this time. I'm starting to get ill with the quality Ford is putting on the streets nowadays.
Fox Fuel Pump Issues After Replacement/Upgrade
  • Ryu
  • Jun 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 5, 2026
Ryu
D
66 Coupe Progress Thread
  • DTCRAWLEY
  • Apr 19, 2026
  • 2 3
1965 - 1973 Classic Mustangs -General/Talk- Jun 17, 2026
DTCRAWLEY
D
R
  • riored97snake
  • Jun 18, 2026
  • What is it Worth?!?!?
riored97snake
R
J
'96 Cobra: A/C gets weak and engine misfires under load when warm
  • jruhnke
  • Oct 22, 2025
  • SVT Tech Forum
SVT Tech Forum Nov 20, 2025
nickyb
L
95 gt engine vibration
  • lenzgt
  • May 11, 2026
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech May 26, 2026
lenzgt
L
  • SVT Tech Forum
