squeaking control arms
  • Thread starter Thread starter EXTRPR50
  • Start date Start date Feb 28, 2007
EXTRPR50
370
  • Feb 28, 2007
Has anyone had probs with BBK control arms squeaking? I need some advise on how to quiet them. Is there some way to lube 'em?
modusmortis
54
  • Feb 28, 2007
unless you have a nipple for a grease gun (i can't remember if the bbk's do or not) you have to remove the control arm, remove the bushings and use silicone grease on the bushings.
SVT32VDOHC
waiting for the next hack atta
3,501
28
119
Motor City
Feb 28, 2007
  • Feb 28, 2007
BBK's do have zert fittings. Get yourself a grease gun and a tube of grease and lube them up. They will quiet down. I would lube them every oil change, or as needed. They are noiser in cold weather too....don't know where you live, but here in Detroit, it's only 30's....
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
Feb 28, 2007
  • Feb 28, 2007
Yep easy job. get a flexable hose for your grease gun it will make it easier.
EXTRPR50
370
  • Mar 1, 2007
Thank you gents..
RED2001GT
20+ Year Stangneter
Mar 18, 2003
270
Mar 1, 2007
  • Mar 1, 2007
grease them
H
habiv
125
  • Mar 1, 2007
My front end squeeks as well after I re-did my suspension. However, I used Ford control arms and there is no grease fitting on the ball joint. I replaced pretty much all of the bushings in the front with polly bushings. I assume this is the cause of the squeeking? I remember people saying that polly bushings are loud, does this sound correct? It is kind of annoying when going over speed bumps
C
Suspension Rear suspension help
  • Clark302
  • Aug 17, 2025
Fox 5.0 Mustang Tech Aug 17, 2025
Clark302
C
Electrical Lincoln Mark VIII Replacement Fan Motor
  • AeroCoupe
  • Sep 26, 2026
Fox 5.0 Mustang Tech Sep 26, 2026
AeroCoupe
R
Suspension Lower control arms needed
  • racer_dave
  • Feb 9, 2026
1974 - 1978 Mustang II Talk & Tech Feb 20, 2026
1968 coupe global west upper control arm template
  • Butchd88
  • Feb 10, 2026
1965 - 1973 Classic Mustangs -General/Talk- Feb 12, 2026
Butchd88
K
Engine Gt40p vs 180 procomp
  • Kleinjj27
  • Oct 27, 2026
Fox 5.0 Mustang Tech Nov 3, 2026
Kleinjj27
K
