  • 1994 - 1995 Specific Tech
squeek when turning
  • Thread starter Thread starter deadlast
  • Start date Start date Jun 13, 2006
deadlast
495
Belmont, MA
Jun 13, 2006
  • Jun 13, 2006
this just popped up, but when i turn i get a loud squeek, like a door hinge w/o oil but lower pitched. it will also surface over bumps, but the squeek is alot louder when turning, than over bumps. im thinking its a busing somewhere, which one should i start with?
1TallMF
955
Montreal
Jun 13, 2006
  • Jun 13, 2006
Thats either your tie rod ends or your balljoints going south. One way to check it would be to jack up the front end and have someone turn the wheel lock to lock to see if you can isolate it better that way. Mine did that exact same thing and it turned out to be balljoints, while others have the same thing happen and it turns out to be tie rod ends. A stethoscope works wonders if you have access to one.
91LX_5L
1,943
British Columbia
Jun 13, 2006
  • Jun 13, 2006
I just did had this prob. I was told more then likely is ball joints but it was actually the tie-rod ends. Like mentioned get someone to turn the wheel while ur under the car, get a metal tube or somthing so you can isolate where the noise is comming from since the ball-joints are very close to the tie-rod ends.
Mine did the squeaking as u described ONLY when I turned the wheel to the left. I poked a hole in the boot and injected it with Lithium grease in a can. It worked. But its more of a band-aid procedure.
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 26, 2026
manicmechanic007
K
Door post and rust repair
  • Kleinjj27
  • Aug 21, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 8, 2026
Kleinjj27
K
A
Engine 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Oct 4, 2026
manicmechanic007
Radio, Speaker Upgrades
  • TripleYellow
  • Apr 24, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 24, 2026
TripleYellow
W
Interior and Upholstery New Member auto dimming mirror install issue
  • WigSnatcher92
  • Aug 25, 2025
1996 - 2004 SN95 Mustang -General/Talk- Aug 28, 2025
Mustang5L5
