• Community Forums
  • Regional Forums and Event Information
North East SSoM Members!!!
  • Thread starter Thread starter whitehorseupnorth
  • Start date Start date Oct 20, 2003
  • 477
  • 478
  • 479
  • 480
  • 481
  • 1056
First Prev 479 of 1056 Next Last
gaslight
3,365
Maine
Sep 14, 2005
#9,561
  • Sep 14, 2005
  • #9,561
Badstang00 said:
I am waiting to here back from James to see what he thinks. If he has the answer, I will test the car this weekend at Epping. If that is not the solution, I will get it dynotuned by Horsepower by Herman next spring.
any relation to Herman Munster? Muster had a kick ass car.
BadVoodoo
1,552
Belgrade
Sep 14, 2005
#9,562
  • Sep 14, 2005
  • #9,562
gaslight said:
You won't loose a bunch of momentum in a split sec. If that were the case then you don't need to use your brakes ever.
If you can gain ET and MPH through powershifting, I would be willing to bet I am losing ET and MPH with this problem.
BadVoodoo
1,552
Belgrade
Sep 14, 2005
#9,563
  • Sep 14, 2005
  • #9,563
gaslight said:
buy your own for $4-5 at the food stand.
Hell no!! That's a gallon+ of gas!!!
gaslight
3,365
Maine
Sep 14, 2005
#9,564
  • Sep 14, 2005
  • #9,564
not that much. Power shifting might give you a tenth or 2.
Just face it. Your car is a TURD
BadVoodoo
1,552
Belgrade
Sep 14, 2005
#9,565
  • Sep 14, 2005
  • #9,565
I hate you.
gaslight
3,365
Maine
Sep 14, 2005
#9,566
  • Sep 14, 2005
  • #9,566
Turd
gaslight
3,365
Maine
Sep 14, 2005
#9,567
  • Sep 14, 2005
  • #9,567
You need some V-Tec
BadVoodoo
1,552
Belgrade
Sep 14, 2005
#9,568
  • Sep 14, 2005
  • #9,568
Shut up!!!!
BadVoodoo
1,552
Belgrade
Sep 14, 2005
#9,569
  • Sep 14, 2005
  • #9,569
Screw you guys, i'm going home!
gaslight
3,365
Maine
Sep 14, 2005
#9,570
  • Sep 14, 2005
  • #9,570
Go get F'ed in the A
gaslight
3,365
Maine
Sep 14, 2005
#9,571
  • Sep 14, 2005
  • #9,571
Turd boy living in a Turd world driving a Turd car
gaslight
3,365
Maine
Sep 14, 2005
#9,572
  • Sep 14, 2005
  • #9,572
Maybe its because you car sucks at producing TORQUE
DoubleONegative
1,528
Tioga Cty PA
Sep 14, 2005
#9,573
  • Sep 14, 2005
  • #9,573
gaslight said:
If that were the case the engine would hit the rev limiter real quick and should be noticeable.
thats true
And yes Mike will loose some velocity with a hesitation between shifts, as the the nose of the car should drop some if there is a hesitation. however the momentum loss will be very slight.
Honestly Mike, something is certainly amiss...i make 100 less RWHP and we are trapping close to the same.
I just hope it isn't anything major
gaslight
3,365
Maine
Sep 14, 2005
#9,574
  • Sep 14, 2005
  • #9,574
whats the matter Mike ?
DoubleONegative
1,528
Tioga Cty PA
Sep 14, 2005
#9,575
  • Sep 14, 2005
  • #9,575
the last guy i heard talking about a hesition between shifts has a 2v GT and he ended up bending a rod
gaslight
3,365
Maine
Sep 14, 2005
#9,576
  • Sep 14, 2005
  • #9,576
I still say its too many double or triple cheeseburger.
gaslight
3,365
Maine
Sep 14, 2005
#9,577
  • Sep 14, 2005
  • #9,577
YOu trying to open up a wound and throw salt in it?
DoubleONegative
1,528
Tioga Cty PA
Sep 14, 2005
#9,578
  • Sep 14, 2005
  • #9,578
Mike this is straight from Ken C at KB
What was causing the hesitation is exactly what I said it was - a high fuel pressure spike at the shifts, then an extreme drop in fuel pressure causing a lean spike. The EEC tries to correct for it, but it's too slow (in terms of computing time) to cure it, hence, a hesitation occurs.
It has NOTHING to do with tip-in spark retard, slipping clutches, belts, etc.. After trying several options with the BAP, I found nothing would pass the Kenne Bell standard for a total "cure". No time delay circuit, adjustment to the boost switch, etc. would make the problem "disappear" completely. We could have probably passed off one of these methods, but it just was not acceptable. After many dyno and street pulls, the correction was found possible within the tune.
gaslight
3,365
Maine
Sep 14, 2005
#9,579
  • Sep 14, 2005
  • #9,579
Hell, I made my numbers without sticky tires, leaving at idle, no powershifting and a bunch of weight in the car.
DoubleONegative
1,528
Tioga Cty PA
Sep 14, 2005
#9,580
  • Sep 14, 2005
  • #9,580
Nope....damn you 2 tore up that lst page, whores!
  • 477
  • 478
  • 479
  • 480
  • 481
  • 1056
M
Too much for me to repair in my current housing situation
  • My Drama Magnet 04 Gt
  • Apr 1, 2026
  • The Welcome Wagon
The Welcome Wagon Apr 14, 2026
J
Exhaust manifold to Y-pipe nut & stud dimensions?
  • joeybuddy96
  • Jul 7, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Jul 9, 2026
joeybuddy96
J
WTB 89 Hatchback interior trim - any color
  • Zero_chance
  • Jun 14, 2026
  • Want to Buy
Want to Buy Jun 14, 2026
P
rear Impact absorbers.
  • Praetorious
  • May 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 5, 2026
Praetorious
P
K
3.8 T5 & Bellhousing to 1987 Lincoln 5.0
  • ks65stang
  • Mar 2, 2026
  • Other Auto Tech
Other Auto Tech Mar 3, 2026
  • Community Forums
