North East SSoM Members!!!
Striped5.0 said:
Not since 1992 when Hurricane Anderw came ripping through. In geological terms a span from 1992 to 2004 is not that long.
Everyone's time comes its just a matter of when. Works the same way w/ tornado's and earthquakes. FL is just in a vounarable positon b/c of the way it sticks out from the mainland
It has nothing to do with sticking off the mainland (thats called a penisula BTW)
The warm water of the Gulf to the west combined with the Carribean's 80+F water and then the Gulf Stream bringing even more warm water from the Topics. ( that s part one ) Then you take hot air coming off mainland africa, starting off with very low pressure. It meets the Ocean and then it begins to pick up more and more moisture. (the warmer the air the more moisture it can hold. Blah Blah Blah Florida just happens to be placed almost perfectly to see about 2 out ever 5 Hurrinanes. Some go north and stay a fish while the other go into the Gulf of Mexico and either die or continue West and the hit florida
There
There
you should go work for the weather channel. :rolleyes:
so you think that sticking out there further in the ocean dosent increase the chance of a hurricane hitting FL ? If one goes through cuba and then takes a hard right where do you think it goes?? Yean right through FL.
There
YAY Golf calp, you know how a hurricane is made. I dident even need the Science channel for that one, I knew that in 6th grade.
I think you need to go back to first grade spelling!!
gaslight said:
yeah right. lame come back. you still got owned on that one.
Lame?? Yeah right, you have nothing to say, looks like your getting owned. :D How do you figure I got owned?? I didn't know that thier numbers were off until reciently. Just because, I haven't changed my sig yet :rolleyes: . You'll have to do better than that. You'll have to admitt. Owning people isn't your forte.
you have know for a while that the numbers are off but you still don't change your sig to reflect that. You were laughing at the ricers! Now we are laughing at you because you won't lower your numbers :p :bs:
You pickle sniffer!
