North East SSoM Members!!!
Badstang00 said:
Correction, I am only running a 15# pulley(3.5") at the moment. Time to upgrade to the RR 17# upper, and idler set :hail2:
Correction, your running 17 psi. Doesn't matter what they say they pulley is. Remember you had me watch the guage. To be honest, it may have went a little above 17psi....
DoubleONegative said:
If Mike is really seeing 17psi shouldn't he be close to say 590RWHP??? or maybe alittle more.
Says who?? Every engine is a little different from the next. There are to many variables in play. The dyno being the biggest factor. There can be differences between the same dyno's. I think he's done well. What really makes you think he really has more in it, at his current boost level? His engine may just not respond as well as some others. I don't know about you kenne bell guys... :rolleyes:
Like Worden said, 99% of guys with similar setups at similar boost levels are right @ the 600 hp mark.......I understand you dinosaur 5.0 guys don't understand this, but thats ok, we love you anyway!!! :D
And.... The pissing match has started.. :D I will believe you, that he has more in it(at it's current psi), if you can tell me what needs to be done to his tune to acheive 600RWHP. Safely.. He's at 12.0 A/F, 21 degs total timing and 78 degs AIT. This should be good.. :rolleyes:
Badstang00 said:
Went down to see Pete and the guys at Performance Dyno yesterday with Chris. I wanted to test out the new tune, numbers are in signature!!
wonder why you don't make more torque than that? I really thought those things would make more torque than that.
Chris did call me on Saturday to tell me you guys were going. I was doing some crap around the house and a little shopping thats why I didn't go. I haven't been on the net since friday so I didn't get your message till today.
