Stainless trim spiff-up, anyone?
  • Thread starter Thread starter CanyonCarver515
  • Start date Start date Nov 8, 2007
CanyonCarver515
122
El Lay
Nov 8, 2007
  • Nov 8, 2007
Hello,
I was told that I can strip the dull anodization with oven cleaner, on the various stainless steel trim pieces around the grille and trunk of my ’67.
I am thinking of polishing them to a mirror-like shine so they look better.
Am I fooling myself or is this something that's been done before?
enferno
418
  • Nov 8, 2007
try brake cleaner and them some #0000 steel wool.
anything more course than #0000 will put tiny scratches, but the 4-aught works great. cleans and polishes
CanyonCarver515
122
El Lay
Nov 8, 2007
  • Nov 8, 2007
Well I am planning on running the trim through my bench buffer and use a stainless steel polishing bar.
Anyone tried this?
Does the polish hold over time. It should, provided that we're dealing with stainless and not aluminum.
Anyone cares to weigh in on this?
T
truck90278
382
Redondo Beach, CA
Nov 8, 2007
  • Nov 8, 2007
Simply buff it with compound, that is all that is needed. use two grits, one, sorry don't recall the specific name it is black in color and then follow up with white rouge. Go on line to Eastwood, their catalogue shows all the different compounds and what they shoud be used for. I polish stainless regularly, I have 10" buff wheels. It will cleanup fairly nicely. It will take some time and it may be difficult to get all the real small scratchs out.
E
entdoc
89
greenville, SC
Nov 8, 2007
  • Nov 8, 2007
I do not believe there is anodization on SS, only aluminum( oven cleaner will strip it). Just polish on a wheel.
66forfun
260
Pittsburgh
Nov 8, 2007
  • Nov 8, 2007
watch out for the crisp corners, you dont want to buff off those. tape up the edges and go slow with the rouge. dont let the wheel grab the part and destroy hard to find parts. good luck.
CanyonCarver515
122
El Lay
Nov 8, 2007
  • Nov 8, 2007
Thank you for the advice. I do have two kinds of rouge and a 10-inch buffing wheel.
I'll be testing this with the old damaged parts I am replacing. It will be good practice.
calpolymustang
217
Santa Rosa, CA
Nov 9, 2007
  • Nov 9, 2007
I had Dave Turner in Fresno, CA polish up all my stainless. He does top notch repair work too (for dents and tears). He might be under Turner Construction in the phone book, cant remember if thats him of not, but my window frames look shinnier than a rapper's wheels.
CanyonCarver515
122
El Lay
Nov 9, 2007
  • Nov 9, 2007
Thank you for the tip.
Laughing about the rapper wheels comparison!
I'd like to see pictures of your car. It sounds pretty peachy.
T
truck90278
382
Redondo Beach, CA
Nov 9, 2007
#10
  • Nov 9, 2007
  • #10
It is difficult to get at home the same results as a professional polisher. While I do small items and bolts, when I want it the best, then I have it done professionally. When professionally done, it looks more like chrome. As 66forfun said be careful. A wheel can grab small parts particularly easy and damage them or more seriously severly injury you when then are grabbed out or your hands. Be sure to wear some gloves and eye protection
CanyonCarver515
122
El Lay
Nov 9, 2007
#11
  • Nov 9, 2007
  • #11
Of course. I actually have polished a lof of items in the past and have a decent experience with it. I have propelled enough bolts and various pieces into the wall or on my legs when I was younger,
enferno
418
#12
  • Nov 10, 2007
  • #12
i believe the polish is called tripoli
CanyonCarver515
122
El Lay
Nov 10, 2007
#13
  • Nov 10, 2007
  • #13
I have heard the term before. You might be right.
bnickel
5,640
lubbock, texas
Nov 11, 2007
#14
  • Nov 11, 2007
  • #14
you want to start with an emory actually. also harbor freight has some pretty dedicated buffing motors for less than $100, if you catch them on sale you get the really nice ones for around $50-65. dedicated buffing motors have more HP and run slower so they don't send parts flying as often.
i used my little cheapie bench grinder to al the stainless on my car and some of the "bright dipped" aluminum. on the aluminum you have to remove the anodizing or "bright dipping" polish the part and clear it.
J
  • JRC99
  • Apr 19, 2025
2K
JRC99
J
Fuel Fuel Pump Rewire, New Fuel Lines, and Installation of New Fuel Pump Hanger with AN6 Connections
  • AeroCoupe
  • Mar 12, 2023
14K
Fox 5.0 Mustang Tech Apr 16, 2023
AeroCoupe
Engine Rocker Noise after Aluminum heads and 1 piece CM Pushrods
  • 79pace
  • Apr 12, 2022
4K
Fox 5.0 Mustang Tech Apr 19, 2022
Monkeybutt2000
M
2004 Mach 1 crank but no start. dying inside
  • gavinmgrant
  • May 23, 2022
  • SN95 4.6L Mustang Tech
  • 2 3
11K
SN95 4.6L Mustang Tech Jun 11, 2022
Mach1.0
M
Price?
  • Blueinfan
  • May 27, 2022
  • What is it Worth?!?!?
5K
What is it Worth?!?!? May 30, 2022
7991LXnSHO
