A slight twist on Shaun's idea is to just run the bleed screw out a little. As you do, the idle will start to return to idle slower, which should act as a buffer to keep the revs from dropping so fast.
Either way should work IMHO - we dont know your existing settings or how the car performs otherwise.
Good luck.
