Stalling On Cold Start
91FoxGT
I've got a '91 5.0 with about 130,xxx miles and about 2 weeks ago it started having trouble on a cold start/idle (dropping to ~200 and almost stalling before bringing it back up), and idle RPM's are sporadic (moves between 600~800). I replaced Distributor Cap, rotor, spark plugs, and wires and it didn't help. Cleaned old IAC Valve, didn't work. Replaced old IAC valve last night, and this morning car actually stalled for the first time (had to gas her to keep her alive), so i don't think that helped either haha.. Once warmed up, car rides fine, starts fine, but still idles a bit uneven. I've read that the ECT Sensor may cause this, but the car doesn't overheat ever. The temp guage never even gets above the middle line, even when running it hard. Fuel Pump does whine like a mother-father, and i've read that can cause stalling itself, but not the low/sporadic idle i've been getting. I never run the car under a half tank of gas.
Only mods on car are cone filter, and BAMA tuning chip. These were done months ago and I don't believe they're part of the problem. Any help would be appreciated.
  • Sponsors(?)
JMGlasgow
Mustang Master
Feb 19, 2017
671
334
93
39
Check codes even if the light isn't on, perform the surging idle checklist that jrichter has. Do a search here for it. Follow it in order, step by step. Don't skip or assume it isn't a necessary check.
Also, I don't have any experience with the BAMA chip, but it may be causing you some issues.
91FoxGT
Ok i just searched up that name and found a bunch of people with the same problem. Will check on those threads. Sorry for yet another repost of the same problem. Thanks for the help
jrichker
StangNet's favorite TOOL
SN Certified Technician
Mar 10, 2000
27,437
2,869
234
74
Dublin GA
lowendmac.com
You guys with idle/stall problems could save a lot of time chasing your tails if you would go through the Surging Idle Checklist. Over 50 different people contributed information to it. The first two posts have all the fixes, and steps through the how to find and fix your idle problems without spending a lot of time and money. It includes how to dump the computer codes quickly and simply as one of the first steps. I continue to update it as more people post fixes or ask questions. You can post questions to that sticky and have your name and idle problem recognized. The guys with original problems and fixes get their posts added to the main fix. :D
It's free, I don't get anything for the use of it except knowing I helped a fellow Mustang enthusiast with his car. At last check, it had more than 200,000 hits, which indicates it does help fix idle problems quickly and inexpensively.
Thread starter Similar threads Forum Replies Date
T 95 GT Cold Start Surging, Occasional Stalling, Intermittent CEL 1994 - 1995 Specific Tech 3
5 Cold Start And Stalling Sometimes When Coming To A Stop Fox 5.0 Mustang Tech 11
J Help Cold Start Stalling SN95 4.6L Mustang Tech 3
tca7291 Engine Arrghhh! Cold Start, Surging/stalling Problem Fox 5.0 Mustang Tech 33
J Cold start stall 2005 - 2009 Specific Tech 7
strtrcr50 Stalling on first cold start Fox 5.0 Mustang Tech 6
CFL2013 2013 sputters then stalls cold 2010 - 2014 Specific Tech 1
98COBRA281 stalling when cold? SN95 4.6L Mustang Tech 2
G '04 Cobra cold-stall problem SVT Tech Forum 2
SadbutTrue Car stalls when cold under hard braking Classic Mustang Specific Tech 13
R Stalling on cold startup Fox 5.0 Mustang Tech 8
J Engine New Manifold nightmare idle and stall 2005 - 2009 Specific Tech 4
J 351W stalls at traffic lights 1965 - 1973 Classic Mustangs -General/Talk- 5
T Car Stalling OUT 2005 - 2009 Specific Tech 1
Dans30250 Motor stalls when turning and stopping Fox 5.0 Mustang Tech 8
B Hesitation and Stalling Classic Mustang Specific Tech 0
trlps_ Fuel Pump causing stalling? 1996 - 2004 SN95 Mustang -General/Talk- 4
G Engine 1993 GT keeps stalling after 30 seconds to a minute when sitting Fox 5.0 Mustang Tech 16
R Engine Engine stalls after running 10 minuter Fox 5.0 Mustang Tech 10
K Traction Control Wont work ( I stall burning out ): ) 2005 - 2014 S-197 Mustang -General/Talk- 2
T Engine Foxbody idling surging and stalling Fox 5.0 Mustang Tech 10
G Engine New AC. Stalling when steering Fox 5.0 Mustang Tech 2
JayMoney4Twenty Running/starting/stalling issue. Fox 5.0 Mustang Tech 7
5 Crankshaft or camshaft position sensor? Car stalls. 1994 - 1995 Specific Tech 5
S Engine Warm stall out Fox 5.0 Mustang Tech 6
P Info for 05-09 Mustang GT owners who have experienced total power loss (dead stalls) after 1-2 hours of hwy driving 2005 - 2014 S-197 Mustang -General/Talk- 1
White Wolf Drivetrain Stall Speed on New Converter 2005 - 2014 Specific V6 Tech 0
S Idle issues, missfire, backfire, stalling 1994 - 1995 Specific Tech 29
M '90 gt stalling issues 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 0
O 2000 plus stall converter. Help 1996 - 2004 SN95 Mustang -General/Talk- 9
G Engine Car running rich stalling out Fox 5.0 Mustang Tech 10
W 98 gt running sluggish/stalls SN95 4.6L Mustang Tech 12
1 Help Diagnosing a 302 that backfires through the carb only under load, sometimes stalls. Fox 5.0 Mustang Tech 2
0 Backfire and stall, won’t crank 1996 - 2004 SN95 Mustang -General/Talk- 3
WildFire07 Engine Engine Stalls with AC on 2007 Mustang GT 4.6L 2005 - 2009 Specific Tech 20
Onesick99GT Low rpm stalling fix 1996 - 2004 SN95 Mustang -General/Talk- 0
Onesick99GT Speedometer Not Working Fix SN95 4.6L Mustang Tech 0
M Engine Car stalls when going to a stop with the AC on Fox 5.0 Mustang Tech 55
D Engine intermitent problem with stalling and torque converter locking up Fox 5.0 Mustang Tech 1
2 theft light fast flashing while driving loss of power stall 1996 - 2004 SN95 Mustang -General/Talk- 3
ppartain Electrical Random Stall Scenario 1992 LX 5.0 Fox 5.0 Mustang Tech 10
S Engine Car Randomly Stalls SN95 V6 Mustang Tech 1
TomOsiris Stalling between shifts, burning smell, check engine light 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 20
A Bogs and Stalls When Hawt!!!! 1996 - 2004 SN95 Mustang -General/Talk- 4
M Progress Thread 2003 Mach stalls SN95 4.6L Mustang Tech 11
EZ123 89 LX stall out and strange idle Fox 5.0 Mustang Tech 9
V 1984 5.0 throttle body convertible stalls when warm Fox 5.0 Mustang Tech 11
S Electrical Stall issue after T5 swap Fox 5.0 Mustang Tech 3
C Stalling and idle issues 2005 - 2014 S-197 Mustang -General/Talk- 3
W 1989 CFD special edition random stall? Fox 5.0 Mustang Tech 10
