Stalling on hot days
  • Thread starter Thread starter helrazr
  • Start date Start date Aug 22, 2005
H
helrazr
36
Regina
Aug 22, 2005
  • Aug 22, 2005
I recently bought a 1988 Mustang coupe with 155,000 kms on it and on hot days sitting at a traffic light it will start to run rough and then stall. Attempting to restart it doesn't work for a few times but after a few minutes it will start and work fine for a few minutes then I get the same problem. The temperature guage reads below the halfway point and the fuel pump always works (audibly) when attempting to restart. I haven't had chance to check the TPS setting or the timing or anything but I believe It's either the coil getting too hot or vapour lock in the fuel lines. Any help is appreciated.
Michael Yount
Mustang Master
Apr 10, 2002
9,039
Charlotte, NC
Aug 22, 2005
  • Aug 22, 2005
Vapor lock is unlikely with an efi car - the system is running up around 40 psig - hard to vaporize it with that much pressure (one of the benefits to always placing a fuel pump at the REAR of the system near the tank by the way).
I'd start by pulling the diagnostic codes out of the computer. WalMart sells code readers for about $30US and the port is part of the wiring harness behind the driver's side strut tower.
stangbear427
2,401
New England
Aug 22, 2005
  • Aug 22, 2005
I wouldn't trust the stock gauge either- they are notorious for being radically in-acurate. My wife's gauge never goes past half way either, but that didn't stop it from over heating. Your well over the 100K mark, invest in some good gauges like Autometers and don't get taken by surprise. Good luck
AUBURN1111
560
20
49
Mobile, AL
Aug 22, 2005
  • Aug 22, 2005
I had the exact same thing happen and it got worse and worse until I had to get it towed, turned out to be computer that was on its way out.
J
Engine Stalling
  • josh40tay
  • Oct 20, 2026
JD1964
Engine Coolant boiling in hose?
  • Teen'93stang5.0
  • Jun 3, 2026
Fox 5.0 Mustang Tech Jun 8, 2026
Mustang5L5
Surging/stalling! problem or tune?
  • djj62478
  • Oct 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 14, 2026
KRUISR
F
2004 Mustang GT – Fuel Pump Not Priming
  • Fayio
  • Apr 22, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Apr 27, 2026
n0v8or
N
Hard to start when engine is cold
  • 86_Capri
  • Mar 11, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
