  • 1994 - 1995 Specific Tech
Stalling problem, used search engine
  • Thread starter Thread starter EHunt
  • Start date Start date Jul 17, 2006
E
EHunt
  • Jul 17, 2006
Hello all,
I used the search engine and could not find anything related to my stalling problem. While driving, if I am at 2000rpms or less when I depress the clutch pedal my car will immediately stall. If I am above 2000rpms by only 100 or more, it will not stall and will just go down to 1000rpm and idle correctly with the clutch pedal depressed. I have cleaned my MAF sensor and my IAC. I do not know what is causing this problem and was wondering if someone here could help =).
Stanger007
2,015
Baton Rouge, LA
Jul 17, 2006
  • Jul 17, 2006
Possibly try replacing the IAC or swapping with another Mustang?
-bump-
HISSIN50
34
129
Jul 17, 2006
  • Jul 17, 2006
Do you have your VSS hooked up?
It could be how the idle is set as well (going back to the IAC thing). I set my idle so the IAC can have 0 duty cycle and the car idles when the engine is hot and there's no load.
Good luck.
G
Idle surging after warm up
  • GALLY3309
  • Jun 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 10, 2026
J
Emission problems
  • jls.zmmr
  • Feb 5, 2026
1994 - 1995 Specific Tech Feb 7, 2026
AeroCoupe
Engine Stalls when downshifting/coasting
  • Scott_S
  • Nov 5, 2025
Fox 5.0 Mustang Tech Nov 6, 2025
Mustang5L5
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 26, 2026
manicmechanic007
