  • 1994 - 1995 Specific Tech
Stalling Problem
  • Thread starter Thread starter xc_myers_06
  • Start date Start date Mar 3, 2006
xc_myers_06
64
Nebraska
Mar 3, 2006
  • Mar 3, 2006
Hey i got a ? about stalling, my car starts goin fine and then the first stop sign i stop at which is 2 blocks away from my house i go to hit the gas and the car acts as there is no gas and then it all of sudden gets it gas and goes. anyone know how to fix this or anything, i am guessin it's with the fuel line or fuel pump unless it is the fuel injectors. i just put in fuel injector cleaner a lil while ago.
HISSIN50
34
129
Mar 3, 2006
  • Mar 3, 2006
Did the car sit for any extended period of time? Is it worse when the motor is cold?
Did it start up one day or was it gradual?
As you can see, any relevant info you can provide will help.
Good luck.
xc_myers_06
64
Nebraska
Mar 3, 2006
  • Mar 3, 2006
it is always right after i start the engine up so it would be cold. it happens almost everytime but it only does it once or twice till i get goin for a while
HISSIN50
34
129
Mar 3, 2006
  • Mar 3, 2006
I would clean the IAC.
xc_myers_06
64
Nebraska
Mar 3, 2006
  • Mar 3, 2006
sorry but what is the IAC?
xc_myers_06
64
Nebraska
Mar 3, 2006
  • Mar 3, 2006
also sometimes when it is cold, it almost sounds like it has a turbo kit on it, the way that they sound but like a lil quieter do you know what that would be? maybe that could be connected or diff.? sorry to overload ya with ?'s but you seem literate with stangs i see your posts all the time
HISSIN50
34
129
Mar 3, 2006
  • Mar 3, 2006
My turbo made a very high-pitched whistle (a lesser version of what you hear from semi's as they go up a hill or get on it) when under moderate boost - is that the kind of noise you hear?
It could be the motor starving for air (due to the IAC not passing enough air when the motor is cold and the throttle is closed) - that will make a sucking of sorts just before stalling or near stalling. Basically the IAC is analogous to a choke when the motor is cold. If you have started a carb'd car with no choke before, the symptoms are very similar.
Though this article seems to be fox based, the systems are pretty congruitious. The pics and stuff might help with cleaning the IAC.
Good luck.
xc_myers_06
64
Nebraska
Mar 3, 2006
  • Mar 3, 2006
Thanks Hissin50, sounds like all the probs. that is occuring, ur help was greatly appreciated
Surging/stalling! problem or tune?
  • djj62478
  • Oct 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 14, 2026
KRUISR
N
Engine 86 GT no start/stall
  • nweber
  • Jul 28, 2026
Fox 5.0 Mustang Tech Jul 29, 2026
AeroCoupe
D
Running both lean and rich with O2 heat codes
  • Danceswithfire5
  • Aug 30, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Sep 5, 2026
apple99Mustangdude
A
T
Fuel P0193 on a 2003 3.8 v6
  • Treemaster5000
  • Aug 18, 2026
SN95 V6 Mustang Tech Aug 18, 2026
Treemaster5000
T
F
1986 mustang no start
  • foxyjamss221
  • Oct 11, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 13, 2025
foxyjamss221
F
