Stalling Problem
  • Thread starter Thread starter thegreentaco
  • Start date Start date Mar 28, 2006
thegreentaco
40
Sacramento
Mar 28, 2006
  • Mar 28, 2006
Ok, I just installed a set of 24# injectors and for the first few days it ran great, but when I started it up one morning it just died. I adjusted the screw on my TB to open the throttle a little to keep it running above 800 rpms but the idle is all over the place from 900-1300. My guess is that my setup cant handle the bigger injectors but also I have a buddy that has pretty much the same setup and he runs them fine. I don't think its the IAC just because it never acted up before. Any advise would be great.
M
Mike92GT
583
Florida
Mar 28, 2006
  • Mar 28, 2006
Did you have the correct sample tube in your mass air meter? Also make sure you don't have any vacuum leaks.
thegreentaco
40
Sacramento
Mar 28, 2006
  • Mar 28, 2006
I just bought the C&L so I don't think its that. I've looked and looked and no vacuum leaks found. The weirdest part about it is that it was running great for 3 days, daily driving all three of them too.
C
cmartin811
Augusta Ga
Mar 31, 2010
  • Mar 31, 2010
Did You ever figure it out b/c I installed the 76mm C&L and 24lbers running full c&l, trick flow intake, 1.7s on a stock cam, 65mm tb, msd coils, race wires and crane hi-6, BBK headers h-pipe SLP resonators w/ turndowns, smog delete w/ 3.55s I would think it would be fine especially w/ the massive spark going on
Surging/stalling! problem or tune?
  • djj62478
  • Oct 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 14, 2026
KRUISR
  • brandyn200
  • Jun 20, 2026
AeroCoupe
Engine Base Idle Reset-Accufab
  • 89notchDude
  • Jun 30, 2025
Fox 5.0 Mustang Tech Jul 22, 2025
Scrapla347
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 26, 2026
manicmechanic007
F
86 notch NEED HELP!!!!
  • foxbody86
  • Jul 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 9, 2026
