stalling problem
  • Thread starter Thread starter CranberryCoupe
  • Start date Start date Nov 28, 2010
C
CranberryCoupe
Summerville, SC
Nov 28, 2010
  • Nov 28, 2010
OK heres what happens: when workin the clutch pulling into the garage or say coming to a traffic light and disengaging the clutch the motor idles up and down from like 200rpm to 1000rpm and will either stall or even out. It does it hot or cold and runs fantastic otherwise. Fuel pressure at idle is fine. any ideas? Thanks for the help!
HISSIN50
34
129
Nov 28, 2010
  • Nov 28, 2010
Any codes?
Any vacuum leaks?
Has the IAC been cleaned or replaced recently?
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Nov 28, 2010
  • Nov 28, 2010
See the "Surging Idle Checklist” for help with all your idle/stall problems. Everything you need to find and fix idle problems is in there.
The first two posts contain all the updates to the fixes. At last count there were 24 possible causes and fixes for surging idle/stall problems. I continue to update it as more people post fixes or ask questions.
arbailey
199
New Jersey
Nov 29, 2010
  • Nov 29, 2010
I have a similar issue with my '88 speed density coupe. It is heavily modified (cam,heads,intake,etc) and runs awesome but has one issue. Now and then as I slow down to a stop to either pull into my driveway or wherever, it will stall. It idles & runs great, but I can't figure out the stalling issue. I want to eventually give the car to my son, but I don't want him killed because the car stalls as he trying to make a turn.
BYRDPE
1,556
Memphis,Tn.
Nov 29, 2010
  • Nov 29, 2010
speed density systems don't like aftermarket cams. have you considered performing the mass air conversion?
C
CranberryCoupe
Summerville, SC
Nov 29, 2010
  • Nov 29, 2010
Thanks for the direction to the troubleshooting section. No codes, dont hear any vaccum leaks. Hopefully I can figure this out. Thanks for the help gents......
Brian
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 26, 2026
manicmechanic007
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2026
JohnKay
J
Hard to start when engine is cold
  • 86_Capri
  • Mar 11, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
P
2000 GT Random Power Loss
  • Pinellas50
  • Mar 9, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Mar 23, 2026
Pinellas50
P
