STALLING PROBLEMS
  • Thread starter Thread starter TITAN STANG
  • Start date Start date May 22, 2004
TITAN STANG
74
  • May 22, 2004
I had it. I have a damn stalling problem that won't quit. I have a 90 LX with Manual trans. I already changed the TFI module, Coil, and the Spark plugs wires. Whenever My car is cold it will stall when I am moving, but whenever I have been driving for a while (about 30 Min Approximately) it stops. I don't want to quit on My Stang', but this is getting annoying. Anybody got an idea what could be causing this?
HISSIN50
34
129
May 22, 2004
  • May 22, 2004
pull codes.
it could be many things. one to keep an eye out for (and check values for):
the ECT and ACT sensors. since you have problems cold, check the cold and warm values for these two sensors. one or both may test within spec, but be incorrect for the situation. i.e. the sensor thinks the car is warm, and leans out (causing stalling when cold), but is actually the correct value for a WARM motor (thus not pitching a code).
good luck.
Mustang John
481
Cleveland, Ohio
May 22, 2004
  • May 22, 2004
Hehe, my trouble is the oppposite!!!
With the advent of th 90 degree weather, my car is stalling at idle under load (like dropping into reverse) when I first start it again after driving it and shutting it off for a few minutes or so. Drivin me nuts... No codes either... sigh...
N
Engine 86 GT no start/stall
  • nweber
  • Jul 28, 2026
Fox 5.0 Mustang Tech Jul 29, 2026
AeroCoupe
Engine Stalls when downshifting/coasting
  • Scott_S
  • Nov 5, 2025
Fox 5.0 Mustang Tech Nov 6, 2025
Mustang5L5
Ford truck engine swap issues
  • keel
  • Jul 7, 2026
  • Other Auto Tech
Other Auto Tech Jul 13, 2026
General karthief
  • brandyn200
  • Jun 20, 2026
AeroCoupe
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2026
JohnKay
J
