Stalling when AC is on
  • Thread starter Thread starter nickmav70
  • Start date Start date Jun 22, 2010
nickmav70
24
Savannah Ga
Jun 22, 2010
  • Jun 22, 2010
Charged my AC and now when i press my clutch in to slow down for a stoplight or stop sign with the A/C the engine stalls completely... if i blip the throttle just as it gets down to about 1000 RPM it will stay running but if i just let it fall it stalls out
Any ideas why?
thanks in advance
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jun 23, 2010
  • Jun 23, 2010
See the "Surging Idle Checklist for help with all your idle/stall problems. Everything you need to find and fix idle problems is in there.
The first two posts contain all the updates to the fixes. At last count there were 24 possible causes and fixes for surging idle/stall problems. I continue to update it as more people post fixes or ask questions.
tims 86
187
pittsburgh,pa
Jun 23, 2010
  • Jun 23, 2010
it could be a compressor failure that is too much drag, check the belt and make sure its ok and not spinning over the pulley.
f8tlfiveo
My wife likes my spool and blow-off valve.
Aug 8, 2007
1,585
102
64
Lancaster, PA
Jun 24, 2010
  • Jun 24, 2010
I have the same problem...what is your car idiling at? I think mine needs cranked up a bit. Mine is idiling at 650-700 most of the time.. I think it should be around 800-850
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jun 24, 2010
  • Jun 24, 2010
Stock idle is 675-725.
See my previous post for the fix for all your/ idle/stall problems.
nickmav70
24
Savannah Ga
Jun 25, 2010
  • Jun 25, 2010
mine idles around 700... it does fine when the ac is not on... accounts for vss input and everything so im thinking my compressor might be going bad... however when i crank it up in the morning it does have a surging idle but only when its cold
thats whats making me think its something else other than the compressor... or in addition to....
any thoughts?
twistedwankel
200
Spring Hill, FL
Jun 25, 2010
  • Jun 25, 2010
any thoughts?
I was told the actual computer controls the idle for AC increase in rpm. So I have to think a bad/loose connection somewhere is keeping the idle from increasing when AC is on if it runs okay otherwise?
Engine Stalls when downshifting/coasting
  • Scott_S
  • Nov 5, 2025
Fox 5.0 Mustang Tech Nov 6, 2025
Mustang5L5
F
Engine 1988 Foxbody idle issues
  • fernandosgarage55
  • Apr 28, 2026
Fox 5.0 Mustang Tech Apr 30, 2026
AeroCoupe
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 26, 2026
manicmechanic007
Ford truck engine swap issues
  • keel
  • Jul 7, 2026
  • Other Auto Tech
Other Auto Tech Jul 13, 2026
General karthief
2001 v6 New compressor issue
  • badmech
  • Apr 30, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Apr 30, 2026
badmech
