hey stangers. I have a stalling under braking ?. I did a 95 MAF upgrade, 65mm FRPP TB,egr spacer, new sensors, o2 sensors, Tmoss intake etc. a little while ago and just getting the time to run it and good weather. checked and rechecked all my lines, plugs etc. I did a base idle set, pulled the idle control motor plug, backed out the set screw until it would just about run, plugged it in and pulled the neg cable to set the ecu. I did the TPS voltage test and set at .98 volts key on. checked timimg which is fine 10degrees advanced. I put in a new oem idle control motor even though my old was fine just because of the age as part of the sensors I changed.
the problem. the car starts and idles fine, a lilttle bumpy but better than before(stock cam) I think it's the normal idle issue. runs and drives great no issues, shifts fine(T5) and the rpms don't drop off in between shifts no issues until I go to stop mostly hard the rpms stumble and the car shuts off, starts right back up and idles fine, now if I tap the gas before the stumble it won't shut off it will catch fine and continue to idle. does the T5 have a vss, maybe that would cause a problem with a sudden drop in speed.
I used my buddues code tester and came up with egr flow insufficient the egr was replaced 2yrs ago new ford, no other codes present. we pulled a vacuum on it and the diaghram was fine, tested the vacuum line and no vacuum at any rpm coming from the egr vacuum soleniod side, but vacuum going in so I got one of those coming.
I need help figuring this out. THE CAR RAN GREAT BEFORE I TOOK IT APART !!! isn't it always the way
. would the egr cause this issue? is the new Idle speed control motor defective? or is the idle to low? I'm going by the stock gauge but i figure I'm atleast 700rpm. any help would be great!!
