starter always engaged
  • Thread starter Thread starter bz393
  • Start date Start date Jun 23, 2009
bz393
29
maryland
Jun 23, 2009
  • Jun 23, 2009
starter will not shut off unless i disconnect the battery. i replaced starter selinoid and ignition switch (recall). this has not fixed anything. im totally stumped. anyone have any ideas.
HISSIN50
34
129
Jun 23, 2009
  • Jun 23, 2009
Do you have a mini starter?
If you disconnect the slide-on connector on the solenoid and it keeps cranking, the solenoid would seem to be latched.
New doesn't mean good, and a weak battery can wipe out a solenoid in one cranking episode.
ID89GT
1,659
18
49
Spokane Valley, WA
Jun 23, 2009
  • Jun 23, 2009
you could also try disconnecting the control wire for the circuit. Maybe it is shorting to another power source somewhere and causing it to stay on. Try disconnecting it and see if the problem goes away. If it does then your control circuit is continually getting power from somewhere. I had this problem and it turned out the wire was cracked right where it goes into the harness and was rubbing next to a fusible link. Worth looking at
bz393
29
maryland
Jun 23, 2009
  • Jun 23, 2009
the battery tested good and it still trys to start with the slide on wire disconnected. also stillcranck over with ign switch disconnected.
F
fastford87
18
Ringgold, GA
Jun 23, 2009
  • Jun 23, 2009
I had the same problem and it was the rod inside the column sticking. You turn the switch and pushes the rod down to power the solenoid and it stays. Did you change the actual ignition switch or the lock and tumbler?
HISSIN50
34
129
Jun 23, 2009
  • Jun 23, 2009
If you have a starter without a piggyback solenoid, change out your fender solenoid. When you pull the old one, test between the normally open and common terminals. It probablywill show very little resistance.
If you have a piggyback solenoid on your starter (you never mentioned if you do), you gotta do one more test to see if it's the piggyback or fender solenoid.
R
rwood126
161
mCdONOUGH, GA.
Jun 23, 2009
  • Jun 23, 2009
My car did the same thing a few months back....the starter got hung and fried the solenoid before I could disconect the battery.
Did you replace the starter too? I had to replace the starter and the solenoid..
Good luck
ID89GT
1,659
18
49
Spokane Valley, WA
Jun 23, 2009
  • Jun 23, 2009
Ya would help to know if you have just the fender mounted solenoid or the one on the actual starter also..
F
fiveohhfox
bronx
Jun 25, 2009
  • Jun 25, 2009
i had the same problem in my 87 gt it was my solenoid every time it stuck i hit the soleinoid with something and it stopped
L
locktyght
#10
  • Jun 25, 2009
  • #10
Just a thought, i know its not on a mustang, but Ive had a starter stick on my 63 galaxie back in the day. The the rod that the bendix slides on had a bur on it and somehow stopped the bendix from kicking back into the starter housing, what a horrible noise that made.
Like i said, this may not help, but then again it might be the problem by some random act of god.
MahFiVeOh
531
9
49
Ontario, Canada
Jun 27, 2009
#11
  • Jun 27, 2009
  • #11
Been there done that.Pretty embarrassing when theres people around and you have to pop the hood and beat the solenoid.
dcurtis
688
Jun 27, 2009
#12
  • Jun 27, 2009
  • #12
I too am looking for a fix to this problem, except mine will go ahead and dis-engage if I put it into drive or reverse, still does it when I put it back into park or neutral though.
Strype
Cuthbert catcher
61
34
104
Huntsvegas, AL
Jun 27, 2009
#13
  • Jun 27, 2009
  • #13
happened to me over a decade ago. Solonoid didnt fix it but a new starter did
Posted via Mobile Device
HISSIN50
34
129
Jun 27, 2009
#14
  • Jun 27, 2009
  • #14
Look for an issue coming from the ignition switch (not the solenoid). The neutral-safety switch allows power from the starter interlock circuit to pass while in P or N but interrupts it when any other gear is selected.
All power lost at crank
  • saf_blu302
  • Mar 7, 2026
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Mar 12, 2026
General karthief
M
85 mustang 5.0 cranking in run position
  • Mamaclean
  • May 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 1, 2026
General karthief
T
Electrical Brown Connector #31
  • ta66
  • Jul 26, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
ta66
T
A
1987 5.0 speed density Foxbody crank no start
  • Alan2204
  • May 23, 2026
Fox 5.0 Mustang Tech May 30, 2026
Mcmahst
D
Mustang not starting
  • Dawry Ramos
  • Sep 12, 2026
  • 2015 - 2023 Specific Tech
2015 - 2023 Specific Tech Today at 9:20 AM
Dawry Ramos
D
