Hello all, i am new to this site and in dire need of help. I have an 83 mustang with a 351c. I recently had to pull the motor due to burning antifreeze. Prior to pulling it, it started/ran fine. I just finished putting the motor back in. hooked up all the wiring (i took a plethora of photos before i pulled it) and all the started does is click. here are the specifics:
T5 manual trans
stock 83 bellhousing
stock 83 starter (just tested okay @ napa)
starter solenoid (new, replaced twice, just in case...)
wiring from battery: 2ga negative to block then block to engine cradle. both wires new (first thought was bad ground) 4ga from positive to starter solenoid. positive post on solenoid also has a green wire (to alt. wiring harness) and a black wire (to yellow fusible link). the other large post has a 4ga wire (also new) to the starter. the battery is about a year old. i took it to the place i bought it to have it checked and charged. just to make sure it wasn't the battery, i also tried hooking up a battery charger and setting it to 60 amp engine start. still nothing but clicks. i have full power on the interior, just won't start...this is absolutely driving me crazy. what am i missing? please help!!!!
T5 manual trans
well me! i was about to say that! I went threw the same dam thing on my 93. All lights would work good and everything but as soon as i would hit the key click! Nothing
I got this tester from a guy at work you hook it to the + &- of your battery and it puts a load on it, as i watched the needle it dropped fast from good to dead! I took it in and they said i had a bad cell in my oh so great $100+ bad ass piece of **** optima battery!
I'll never buy another one of those batteries espically after seeing 4 more of them on the cart they set mine on with the same problem! Interstate batteries all the way! FTW! peace
