starter heat soak
  • Thread starter Thread starter bi19tri
  • Start date Start date Aug 26, 2006
bi19tri
45
  • Aug 26, 2006
Are ford starters prone to heat soak issues?
HISSIN50
34
129
Aug 26, 2006
  • Aug 26, 2006
The earlier aero fox ones with aftermarket headers can be. Ford went with a smaller starter in about 92 or so.
An aftermarket or 94-95 starter is a nice upgrade if your starter is long in the tooth.
Good luck.
83gt5oh
  • Aug 27, 2006
What kind of problem are you having?
dastang2
2,020
tx
Aug 27, 2006
  • Aug 27, 2006
all starters can get like that with exhaust right next to it.
RacEoHolic330
I like to dress like a pretty girl
4,014
1,698
203
Allentown, PA
Aug 27, 2006
  • Aug 27, 2006
I had a heat soak issue on my 88 when I had that stock starter. If I drove around for a while and then shut my car off it would have a real hard time cranking up again. It almost seemed like the battery was dead. But if i let the car cool down, it was fine. Replaced it with a high torque mini starter and the problems went away.
wythors
Get off my lawn!!!
2,277
35
69
C Addle
Aug 27, 2006
  • Aug 27, 2006
Are you running long-tube headers? If so, then "yes".
Electrical Starter solenoid out of space?
  • 387lx
  • Jan 22, 2026
Fox 5.0 Mustang Tech Jan 23, 2026
387lx
Electrical Starter solenoid green wire?
  • 387lx
  • Jun 1, 2026
Fox 5.0 Mustang Tech Jun 2, 2026
AeroCoupe
Engine 5.0 Head Gaskets installed wrong block coolant passages???
  • Xam Sirrah
  • Jul 21, 2025
Fox 5.0 Mustang Tech Dec 22, 2025
Qtrhrse23
Electrical Mini-Starter Wiring
  • RekeHavoc
  • Jul 25, 2025
2K
Fox 5.0 Mustang Tech Aug 24, 2025
Mustang5L5
M
Bad starter?
  • mason5.0
  • Oct 6, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 6, 2026
General karthief
