Starter? I dont know
  • Thread starter Thread starter quiksilver9531
  • Start date Start date Jul 18, 2004
quiksilver9531
469
New Jersey
Jul 18, 2004
  • Jul 18, 2004
This is really strange and Im kinda clueless to why its doing this, but heres whats happening..i have a brand new alternator, PA-performance 3g alt, and a brand new battery, anyway it will crank over like regular and then after the car is warmed up it cranks over so slow it acts like the batterys dead, but it will keep turning over really slow and start and then like a few hours later it will start wwill like normal...any ideas? I mean the only thing i could think of is maybe the starter is going?
W
WolfDog50
Southern NY
Jul 18, 2004
  • Jul 18, 2004
Starter death is usually by heat soaking. Is the prob only when the car has been warmed up? If so, then you may be right about the bum starter. If the car shows symptoms when its cold, you may try hunting down a bad ground or loose cable.
quiksilver9531
469
New Jersey
Jul 18, 2004
  • Jul 18, 2004
it only happens when its warmed up
ponyboy19
1,640
Jul 18, 2004
  • Jul 18, 2004
what's your timing at.. sounds like you may have it way to far advanced. could it be off or your distributor maybe moved? you may want to check/back it off a bit and see.
quiksilver9531
469
New Jersey
Jul 18, 2004
  • Jul 18, 2004
no i havent touched the timing so its stock timing..its probably the starter..it runs perfectly fine
ponyboy19
1,640
Jul 18, 2004
  • Jul 18, 2004
yeah it will run ok.. but if the timing gets to far off hot starts becomes a real problem. Cold starts will remain fine. may not be your issue but I'd check it with a light with the spout out and make sure it's between 10-14 degrees.
J
johnkeltgen
30
Cologne, MN.
Jul 19, 2004
  • Jul 19, 2004
I've got the same problem with my '84 GLX. Timing, huh? Well, I'll be up at Brainerd next weekend... have to get her checked out!
M
Bad starter?
  • mason5.0
  • Oct 6, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 6, 2026
General karthief
M
Fox Random spike voltage (Need help from scope users)
  • martroy
  • Sep 28, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 27, 2026
martroy
M
Alternator not charging
  • SchwarzStock
  • Jul 6, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 17, 2026
SchwarzStock
A
1987 5.0 speed density Foxbody crank no start
  • Alan2204
  • May 23, 2026
Fox 5.0 Mustang Tech May 30, 2026
Mcmahst
Electrical Crank-no start ... no spark ... no injector pulse, was it something I did? (redux)
  • 85gtCOBRA
  • Oct 28, 2025
Fox 5.0 Mustang Tech Oct 29, 2025
85gtCOBRA
