  • SN95 4.6L Mustang Tech
Starter Install?????
  • Thread starter Thread starter stanglover01
  • Start date Start date Jun 25, 2005
stanglover01
  • Jun 25, 2005
Is it hard to install a starter on a '01 GT 5-speed. B/c i am trying to decide if i want to do it or if i should pay someone and what will i need to install it.
Superhereaux
chicks make me feel inadequate
538
South Texas
Jun 25, 2005
  • Jun 25, 2005
do it yourself
a set of wrenches or a ratchet and some sockets (metric) is all you really need, and jack stands of course
it'll take you a good couple of hours to do it since you've never done it, but once you do you'll be able to do it again in half the time or faster. not much you can mess up too bad replacing a starter (disconnect neg. batt. terminal)
btw,
are you positive it's the starter that's bad? did you check all the wires, fuses and relays?
blackink00
I missed a shift & stole Curt's money.
Mar 30, 2005
545
Tempe, AZ
Jun 25, 2005
  • Jun 25, 2005
youll need to know a trick on the starter. there are three bolts holding it on, two on top one on bottom. the bottom is easy just take it off. the top two use a long extension (like two feet) and a swivle with the socket on the end and go through where the motor mount and the k-member are. it is a straight shot. its a pain the first but then its pretty easy. also i only put back on two of the bolt on the top and bottom. hope that helps
O
ocelot
96
  • Jun 25, 2005
It's extremely easy. If you just look at where the starter is, you'll be able to tell what bolts are holding it in, and once they are out, just take it out and you'll know how to put it back in.
9
97gtblue
283
pensacola,florida
Jun 25, 2005
  • Jun 25, 2005
thats the easiest way i found to,and ive had my transmission out twice already.the first time took a long time but then i did it through the k member thing and if only took about 30 minutes
Alternator not charging
  • SchwarzStock
  • Jul 6, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 17, 2026
SchwarzStock
Progress Thread 91GTstroked 90 7 up convertible build
  • 91GTstroked
  • Apr 18, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 22, 2026
91GTstroked
Electrical Starter solenoid out of space?
  • 387lx
  • Jan 22, 2026
Fox 5.0 Mustang Tech Jan 23, 2026
387lx
C
98 gt fuel pressure issues
  • chasecollier1984
  • Jun 2, 2026
SN95 4.6L Mustang Tech Jun 2, 2026
chasecollier1984
C
Engine Starter ring gear depth. 3/8 or 3/4 inch?
  • 92Rustang
  • Aug 4, 2025
Fox 5.0 Mustang Tech Aug 22, 2025
Rcdgl
R
