  • 1994 - 1995 Specific Tech
starter keeps starting...
  • Thread starter Thread starter 95CobraMike
  • Start date Start date Aug 31, 2004
95CobraMike
1,046
Lima OH
Aug 31, 2004
  • Aug 31, 2004
ok so i recently got my car to start when it was hot, (stator/dizzy pick-up) but now alot of times i have a problem where i start the motor and the starter keeps trying to start the motor, even when you shut the key off, i have to get out and dissconnect the battery to make it stop...i have replaced the ignition tumbler thing where the key goes in and the switch that is under the steering column, i thought it might be the solenoid on the starter, but it is a new starter, less than 2 months old...i wouldnt think it is that. please help me
95CobraMike
1,046
Lima OH
Aug 31, 2004
  • Aug 31, 2004
could it be my battery?
W
wytstang
Mustang Master
Mar 14, 2004
4,988
Summerville,SC missing South Fl. weather :(
Aug 31, 2004
  • Aug 31, 2004
It sounds like the starter is sticking. Take it back for another one. I don't think the battery could cause this. Maybe the starter relay is shot but I don't see how that could cause this but it's a thought.
HISSIN50
34
129
Aug 31, 2004
  • Aug 31, 2004
if you can, disconnect the solenoid trigger wire (thin wire) when it does this. if the starter continues cranking away, it should be the solenoid sticking.
you can also put a test light on the trigger wire - if it stays illuminated when the key is not turned to 'crank', an interlock device is at fault.
good luck.
95CobraMike
1,046
Lima OH
Aug 31, 2004
  • Aug 31, 2004
is there a starter relay? i dont believe there is one on the 94-95...maybe i am wrong.
there are 2 wires that go to my starter, i thought one was the positive and the other is the ground...there is a trigger wire? what color is it?
thank you for your help so far...
HISSIN50
34
129
Aug 31, 2004
  • Aug 31, 2004
starter solenoid = starter relay (i usually call it the latter as some folks - no one here- dont know what a solenoid is).
Rootus
Officially Addicted
Feb 8, 2003
6,659
Portland, Oregon
Aug 31, 2004
  • Aug 31, 2004
Yeah, speaking of which, what is a solenoid?
J/K
Dave
HISSIN50
34
129
Aug 31, 2004
  • Aug 31, 2004
J/K
Dave
LOL, Dave. now i would have felt stupid if you had [facetiously] asked what a relay was (my whole reason for calling the solenoid a relay). LOL.
95CobraMike
1,046
Lima OH
Sep 1, 2004
  • Sep 1, 2004
well i made it do it again, and took the little signal wire off and it kept going, so it is the solenoid, which is weird for 2 reasons...
1. it is a new starter and solenoid
2. i took it off the car and hooked it up to a battery charger, and i couldnt get it to stick for me on the charger on a 12 volt low setting...i tried it like 25 times without it sticking.... then i put the charger to 6v high start (lower voltage) then it did stuck....i put the charger back on 12 volts and it continued to do it every time....i don tknow i am bringing it back and getting a new one.... for reason #2 is why i thought my battery may be not quite strong enough? who knows...
W
wytstang
Mustang Master
Mar 14, 2004
4,988
Sep 1, 2004
#10
  • Sep 1, 2004
  • #10
In that case check your voltage your alt may be the culprit. Or your battery is going out and is weak. Auto zone/Discount will check your battery for free.
95CobraMike
1,046
Lima OH
Sep 1, 2004
#11
  • Sep 1, 2004
  • #11
got a new starter and solenoid, hasnt done it since....knock on wood...
M
85 mustang 5.0 cranking in run position
  • Mamaclean
  • May 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 1, 2026
General karthief
All power lost at crank
  • saf_blu302
  • Mar 7, 2026
1994 - 1995 Specific Tech Mar 12, 2026
General karthief
Electrical Starter solenoid out of space?
  • 387lx
  • Jan 22, 2026
Fox 5.0 Mustang Tech Jan 23, 2026
387lx
C
Electrical HELP! 1989 5.0 Stick, Voltage Bleed onto Ignition Trigger wire
  • ChickenDeluxe
  • May 14, 2026
Fox 5.0 Mustang Tech May 24, 2026
ChickenDeluxe
C
A
1987 5.0 speed density Foxbody crank no start
  • Alan2204
  • May 23, 2026
Fox 5.0 Mustang Tech May 30, 2026
Mcmahst
