starter problem
  • Thread starter Thread starter 1991vert
  • Start date Start date Mar 6, 2004
1991vert
1,103
Ludlow, MA
Mar 6, 2004
  • Mar 6, 2004
it occurs randomly, but ever since i switched my transmission, my starter tends to get pms. i'll go to start the car and when i turn the key, the starter will just whine, then i'll turn the key back and try it again and the car will start. it doesn't happen everytime, just occasionally. think it's time for a new starter? appreciate anyone's input thanks
HISSIN50
34
129
Mar 7, 2004
  • Mar 7, 2004
this has been goin around lately.
i would check your cables really well. they can corrode from the inside out. cleaning the connections or replacing the cables should do it.
now if it happens only when the car is hot, could be heat sink. does not sound like it in your case. last choice is a bendix problem, also not likely. check connections. dont forget the starter cable if the others dont fix it.
good luck
NeQX
904
Infront Of You, NY
Mar 7, 2004
  • Mar 7, 2004
I was having that problem, try banging starter with hammer or rolling and popping clutch. I got sick of that so.....I got a nice hi torque starter for not too bad of a price from www.pa-performance.com (the place that is famous with mustangs and 3g upgrades) came with upgraded power wire...car cranks like a BEAST!
1991vert
1,103
Ludlow, MA
Mar 7, 2004
  • Mar 7, 2004
well i remember when i did hte tranny swap and took the starter out. it looked kind of crappy in there to say the least. think i should take it out and clean it? or is it supposed to look black with junk caked on to it? lol
thanks
HISSIN50
34
129
Mar 7, 2004
  • Mar 7, 2004
i would not really worry about how dirty the starter is (clean is always better and more efficient. dirt holds heat and moisture). but, i would not bother unless you are having hot start issues (heat sink), or you are bored.
check cables and motor to chassis cable.
good luck.
P
plainwrecknate
92
Fort Morgan, CO
Oct 5, 2005
  • Oct 5, 2005
we had that problem with my dad's 81 F350, it just whined like crazy. and since i was just starting with the mechanic stuff, i decided to replace it. when i took it off, there were metal shavings in the starter... whoever had the truck before or whatever only mounted on of the mounts for the starter, it shifted and the flywheel was grinding on the actual body :/
i know this is an old thread, but i was doing a search since my starter is almost shot.
DemonGT
871
51
49
Sparta,WI
Oct 5, 2005
  • Oct 5, 2005
oops
9
91fxbdy
Orange County
Oct 5, 2005
  • Oct 5, 2005
The bendix may be bad or you have have a chiped tooth on the flywheel?
The only way to check the flywheel is pull off the starter and have someone turn your motor and check it out.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Oct 5, 2005
  • Oct 5, 2005
Bendix going bad or the solenoid on top of the starter that moves the Bendix is going out. either way, it means replacing the starter.
Paul Perreca
1,085
#10
  • Oct 5, 2005
  • #10
mine did this same thing, when i took it off, there was a rot hole in the friggen thing lol it must have been from the hole lol
1990LXDropTop
430
Western Massachusetts
Oct 5, 2005
#11
  • Oct 5, 2005
  • #11
Not sure if anyone else realized this, but the original post by 1991vert is from 3/7/04.
C
Electrical HELP! 1989 5.0 Stick, Voltage Bleed onto Ignition Trigger wire
  • ChickenDeluxe
  • May 14, 2026
Fox 5.0 Mustang Tech May 24, 2026
ChickenDeluxe
C
  • Mindseye007
  • Aug 16, 2026
Mindseye007
A
1987 5.0 speed density Foxbody crank no start
  • Alan2204
  • May 23, 2026
Fox 5.0 Mustang Tech May 30, 2026
Mcmahst
Electrical Crank-no start ... no spark ... no injector pulse, was it something I did? (redux)
  • 85gtCOBRA
  • Oct 28, 2025
Fox 5.0 Mustang Tech Oct 29, 2025
85gtCOBRA
T
Electrical Brown Connector #31
  • ta66
  • Jul 26, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
ta66
T
