Starter relay Question
  • Thread starter Thread starter carbed 85 gt
  • Start date Start date Apr 8, 2006
carbed 85 gt
121
Honolulu HI
Apr 8, 2006
  • Apr 8, 2006
Hello, I am moving some of my harness inside of the fenders and just did the starter relay. Now the starter stays engaged for a half second after the car starts. I have the two posts. the one that the starter is wired to has two wires coming off of it and the rest of the wires for fusible links are on the post which has the Positive cable correct? I am not sure if I have a problem whith the relay or my own fault.
thanks
HISSIN50
34
129
Apr 8, 2006
  • Apr 8, 2006
It seems to me that my starter lug only has the starter cable on it - no other cables.
carbed 85 gt
121
Honolulu HI
Apr 9, 2006
  • Apr 9, 2006
I will look again but I think I have another wire on that lug. Thanks
carbed 85 gt
121
Honolulu HI
Apr 9, 2006
  • Apr 9, 2006
carbed 85 gt
121
Honolulu HI
Apr 9, 2006
  • Apr 9, 2006
stang&2Birds
2,091
New England. :-) CT/MA
Apr 9, 2006
  • Apr 9, 2006
Chances are you're not providing enough information. I'll bet that you have a newer starter on your car. You may or may not know the difference between the orig starter and the newer starters that have the relay on top of them. But, that's a good example of the problems you'll have with repairing your car and the help that you'll get in the forums if you don't provide all of the relevant information.
Unless you say what is *different* on your car than stock, you'll often get wrong advice.
Check out your starter. Does it have place for JUST one wire? Or does, it have two wire lugs? One big (battery), and one smaller (start from the **KEY**).
If you have a newer starter and the smaller starter relay wire goes to the same terminal on your FENDER relay as the big starter wire, then that WILL HAPPEN.
There's "little difference" between a starter and an alternator. The newer starters are more efficient. So, when the engine starts and before the stater disengages, the starter GENERATES VOLTAGE onto that Big wire. Now, if the smaller relay engage wire (on the starter) is connected to that Big wire, the voltage and current generated by the starter will be enough to keep the relay energized. So, the starter "hangs".
For the NEW type of starters, the smaller relay engage wire on the starter MUST go to KEY start wire. It can **NOT** be just connected to the big "starter" post on the FENDER relay.
If someone says "I did it and it works fine", tell them that they are WRONG! A number of years ago, Ford started putting the same info on their Starter Upgrade *kits*. Before Ford did that, morons would argue to NO END that what I said was *not* true because they may not have HEARD the starter hang. - roll_eyes
BTW: It is a simple and UNDERSTANDABLE mistake to make when doing a starter upgrade.
stang&2Birds
2,091
Apr 9, 2006
  • Apr 9, 2006
The new style starter vs the old style starter:
http://www.veryuseful.com/mustang/tech/tmp/starter-new-vs-old-pic1e.jpg
The new style stater:
http://www.veryuseful.com/mustang/tech/tmp/starter-new-style-pic1.jpg
Electrical Mini-Starter Wiring
  • RekeHavoc
  • Jul 25, 2025
2K
Fox 5.0 Mustang Tech Aug 24, 2025
Mustang5L5
T
Electrical Brown Connector #31
  • ta66
  • Jul 26, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
ta66
T
C
Electrical HELP! 1989 5.0 Stick, Voltage Bleed onto Ignition Trigger wire
  • ChickenDeluxe
  • May 14, 2026
Fox 5.0 Mustang Tech May 24, 2026
ChickenDeluxe
C
Alternator not charging
  • SchwarzStock
  • Jul 6, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 17, 2026
SchwarzStock
Resolved Holley terminator integration into CCRM
  • BrandonMP
  • Feb 25, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Aug 23, 2026
fasterthangas
F
