Starter ?
  • Thread starter Thread starter rwood126
  • Start date Start date May 3, 2009
R
rwood126
161
mCdONOUGH, GA.
May 3, 2009
  • May 3, 2009
I have a 89 vert ...sometime when I go to start it ..it sounds like the starter spines but it's not ingauging . Then I wait a minute and turn the key and it spins over and cranks.
I have new OEM cables and OEM solenoid.
Any suggestions?
TRWXXA
190
RIGHT BEHIND YOU!!!... Made you look.
May 3, 2009
  • May 3, 2009
Any suggestions?
Sounds like it's time for a new or rebuilt starter. This is not a problem that gets better over time. If you still have the old style, stock starter, think about upgrading to the new "mini" starter. You just need to make a little wiring modification.
R
rwood126
161
mCdONOUGH, GA.
May 3, 2009
  • May 3, 2009
Thats what I thought.....
Is the starter hard to get to?
Thanks
ID89GT
1,659
18
49
Spokane Valley, WA
May 3, 2009
  • May 3, 2009
Thanks
Not to bad, I usually just use a bunch of extensions and wobblys for the top bolt, then just go under the car for the bottom bolt and it comes right out.
Turd Tops
103
South Lyon , Michigan
May 3, 2009
  • May 3, 2009
I 2nd replacing the starter but dissagree with getting the "mini" starter. What would be the point? It does'nt sound the like you need the extra room or the extra torque you gain from the "mini" starter. Take the money you save and buy something usefull. I'm not saying it a bad upgrade but if you don't need it whats the point?
TRWXXA
190
May 4, 2009
  • May 4, 2009
The "mini" starter pulls its power from from the battery side of the starter relay. Only the power to the starter solenoid is on the switched side of the relay. Low current going through the relay reduces its chance of failure.
The smaller starter has greater clearance from the headers. Less heat goes into the starter increasing its life.
The "mini" starter draws fewer amps.
The "mini" starter weighs nearly 10 lbs. less.
What's the price difference? $20?
Electrical Starter solenoid out of space?
  • 387lx
  • Jan 22, 2026
Fox 5.0 Mustang Tech Jan 23, 2026
387lx
J
Engine Stalling
  • josh40tay
  • Oct 20, 2026
JD1964
C
Electrical HELP! 1989 5.0 Stick, Voltage Bleed onto Ignition Trigger wire
  • ChickenDeluxe
  • May 14, 2026
Fox 5.0 Mustang Tech May 24, 2026
ChickenDeluxe
C
T
Electrical 1990 Vert starting/Solenoid issues
  • Tom77
  • Apr 18, 2025
Fox 5.0 Mustang Tech Apr 18, 2025
85GTStangGuy
M
85 mustang 5.0 cranking in run position
  • Mamaclean
  • May 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 1, 2026
General karthief
