starting issue 03 mustang gt
fmd28
31
Las Vegas, NV
I think that my starter on my modified GT is either OOC or could it be some thing else? Problem I have is the vehicle will not start when I turn the key. I don't hear any sounds and I know the battery is good due to we tried a jump start and no start up. I believe it is the starter due to when I changed the cams it requires a longer time to start up. Any suggestions on this be apprecative.
When you turn the key, can you hear a 'click'? This is the starter solenoid. If you do not hear a click, then it may be as simple as replacing that solenoid. If you do hear a click, then pull off the starter and have your local parts store test it.
