starting issue...confused!
  • Thread starter Thread starter 87WhiteStang1
  • Start date Start date Nov 6, 2008
87WhiteStang1
182
  • Nov 6, 2008
ok so i am pretty sure that my battery is dead because it died on me twice in the past week...but up until today i could hook it up to my charger for a few minutes and start it. today at first when i was trying to start it it would really try but not enough to start it...then finally it would just click when i turn the key... so i let it charge longer and still all it will do is click...then if i keep trying the thin cord that goes from the neg. terminal on battery to the fender wall starts to smoke and burn up??? i have no idea why that would happen...give me some help here so i can get her running!THANKS
snakebite01
81
new jersey but not for long
Nov 7, 2008
  • Nov 7, 2008
well that cable is hooked up to the fender wall start solenoid.. what i would do first is take it to a local auto parts store like advance auto parts or auto zone and have them test the battery.. if it comes up bad than try putting a new one in.. if that doesn't work than get a new fender mounted started solenoid. if that's not it than you will have to get a new starter. those are the only things it could really be
87WhiteStang1
182
  • Nov 7, 2008
ive already replaced the starter solenoid...even if the battery is dead i dont understand why that wire would get so hot and start smoking? i think i will get a new battery and maybe if im lucky it will work again but if not i guess i will be looking into starters
L
LxVert
80
  • Nov 7, 2008
Could be the cable it self is bad, I would replace the cable and see if it makes a difference.
885.0conv
238
Phoenix, Az
Nov 7, 2008
  • Nov 7, 2008
I would guess the cable like LXVert said because if the resistance is too high it will draw more current causing it to smoke
T
tiptop
73
  • Nov 7, 2008
starter
hotcobra03
poteet,tx
Nov 7, 2008
  • Nov 7, 2008
Dirty or loose connection are most common.starters would be 2nd.shorted cell in battery 3rd. Try tapping on starter if it starts change starter
87WhiteStang1
182
  • Nov 7, 2008
ok tomarrow i will try replacing that wire...we'll see what happens..feel free to give me any other tips. thanks guys
snakebite01
81
Nov 8, 2008
  • Nov 8, 2008
i agree.... replace the cable, well one that is the cheapest route. if not that i would get a new starter. i highly doubt it's the battery causing the trouble...
87WhiteStang1
182
#10
  • Nov 9, 2008
  • #10
okay so i replaced that wire...i got a new battery. put the bat. in and started right up a few times...i drove it for a while and it barely cranked so i had to push it to start it...i drove somewhere else and it then it BARELY started...im thinking alternator but...i used a multimeter and hooked it to the battery...the battery sits at 12.68 when engine iff and 14.38 with engine on...
L
LxVert
80
#11
  • Nov 9, 2008
  • #11
Hm, the only other thing I can say is agreeing with everyone that said starter. The starter could be drawing to much current.
Buy a new starter, put it in and see if it fixes the problem (wouldn't return the core until you find out), if not pull it out and get your money back.
87WhiteStang1
182
#12
  • Nov 10, 2008
  • #12
oh i was hoping it wouldnt come down to that...one more thing i might try is taking the UD pulley off of the alternator and putting the stock one back on and see whether that makes any difference in charging
69must
#13
  • Nov 10, 2008
  • #13
Starting trouble
Did you replace the ground cable or just the thin wire to the fender. I would make sure that the ground cable has a good connection to the block.
87WhiteStang1
182
#14
  • Nov 11, 2008
  • #14
i replaced both battery cables about a year ago...i have cleaned off all conections to the solenoid(which has also been replaced) but i might try to clean the groung to block connection up a bit and maybe the connection to the starter as well...we'll see what happens
A
1987 5.0 speed density Foxbody crank no start
  • Alan2204
  • May 23, 2026
Fox 5.0 Mustang Tech May 30, 2026
Mcmahst
Electrical Code 29 again
  • Creomod
  • Jul 31, 2026
Fox 5.0 Mustang Tech Aug 3, 2026
Creomod
G
Resolved Smoking Wiring Issue After GT40 Head Swap
  • Grapes
  • Aug 15, 2026
Fox 5.0 Mustang Tech Aug 22, 2026
Grapes
G
Electrical Lincoln Mark VIII Replacement Fan Motor
  • AeroCoupe
  • Sep 26, 2026
Fox 5.0 Mustang Tech Sep 26, 2026
AeroCoupe
92 5.0 almost starts
  • Steverino
  • Sep 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 25, 2026
General karthief
