Ok, so my T-5 trans has been sitting in the garage for almost 2 years now and since I think I broke either my clutch fork or pressure plate, it's finally time to put it in! I was going to have a professional do the work who has done a number of swaps before but he recently injured his back to the point of having to sell his shop. So, I started to think about who else I would have do the work and then thought, "hell, I'll just do it myself". So here goes.
I got most of my parts from Modern Driveline and just sent Bruce an e-mail to finalize any remaining parts. I have a '70 sportsroof w/ a modified 289 and a 4spd toploader. I'm planning on using a late model bellhousing w/ my original mechanical clutch linkage. This is what I already have:
World Class T-5 w/ shifter
New Centerforce clutch and pressure plate
New Late model bellhousing w/ fulcrum adapter mounted
crossmember
trans mount
block plate
speedo cable and gear
flywheel and pressure plate bolt kit
If I remember correctly, my current yoke should fit the T-5 but I will need to have my drive shaft shortened. I have also read that a '91 or later Aerostar yoke and shaft can but used if the shaft is also shortened. Would this be worth doing if I wanted to upgrade to an alum shaft? Or, is there another vehicle that would have the right length shaft already?
The new clutch and pressure plate I have is for a late model 5.0. Should I change my flywheel to a late model as well and then do I need to worry about harmonic balancer compatability? Also, I guess I would then use a late model starter as well.?
Also, I'm asssuming I would still use an early throwout bearing. since I'm using the original linkage and fork.
While I am rounding those up I will go ahead and pull the toploader out and get anything else ready. I'll keep you all posted on my progress but any advice would be welcomed.
crossmember
trans mount
block plate
