starting problem
  • Thread starter Thread starter treky5
  • Start date Start date Feb 11, 2006
T
treky5
10
long island,n.y.
Feb 11, 2006
  • Feb 11, 2006
recently when I start my car it turns over and stops and then when I try to start it again it starts I don't know what it could be .
HISSIN50
34
129
Feb 11, 2006
  • Feb 11, 2006
I would go over all the primary electrical cables. Battery connections, solenoid connections, and battery/motor grounds. It sounds like a ground issue to me, but giving them all a cleaning should help out in the future (corrosion is funny in that you can't visually see the layer of insulating muck, but it makes a difference when passing large current like for the starter).
Good luck.
axeman
1,348
Elizabethtown, PA
Feb 11, 2006
  • Feb 11, 2006
timing could be off. have you messed with that lately? on another vehicle that I had, the timing was off because the key that lined the harmonic balancer on the crank was worn and allowed the it to turn, so I adjusted to the wrong setting. took me forever to figure that one out.
T
treky5
10
long island,n.y.
Feb 12, 2006
  • Feb 12, 2006
Thanks for your help I recently had a new starter and solenoid put in I will check the connections .The timing might be off . A year after I had my 340hp crate motor put in the timing jumped way up what would you set the timing at.
HISSIN50
34
129
Feb 12, 2006
  • Feb 12, 2006
I would be around 12-14* with irons and perhaps a little more with alum. I would play it safe and bump up till you hear some detonation. Then back it down a couple degrees.
5.0 Nostalgia
904
CT
Feb 13, 2006
  • Feb 13, 2006
I second Hissin's suggestion about the connections. I had a similar issue at one time. When I pulled my battery out I found the starter ground wire was corroded and only hanging together by a thread.
axeman
1,348
Elizabethtown, PA
Feb 13, 2006
  • Feb 13, 2006
grounds sure can do some weird things. since you recently had some work done, i would check your wiring first.
A
1987 5.0 speed density Foxbody crank no start
  • Alan2204
  • May 23, 2026
Fox 5.0 Mustang Tech May 30, 2026
Mcmahst
Engine Another no start after washing engine bay
  • bruno
  • Apr 26, 2026
Fox 5.0 Mustang Tech May 7, 2026
AeroCoupe
D
Mustang not starting
  • Dawry Ramos
  • Sep 12, 2026
  • 2015 - 2023 Specific Tech
2015 - 2023 Specific Tech Oct 3, 2026
Dawry Ramos
D
92 5.0 almost starts
  • Steverino
  • Sep 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 25, 2026
General karthief
  • Mindseye007
  • Aug 16, 2026
Mindseye007
