Hello,
I did something I probably shouldn't have done (hindsight is 20/20, I guess).
I was having problems starting the car, and it seemed to have something to do with the positive battery cable. When I wiggled it, there was some power, but not enough to start.
So, what I did, which I probably shouldn't have done, was to connect the positive battery terminal to the place where the positive battery cable goes (starter relay), using a jumper cable.
Anyway, the car started, but I think the starter motor kept going and wouldn't stop. So, I turned off the car.
I walked to a Pep Boys and got a replacement battery cable (4 gauge), and replaced the positive battery cable.
Now, every time I connect the battery cables, first connecting the positive cable, there are huge sparks when I try to connect the negative cable.
The one time I actually had the courage to fully connect the negative cable, the car started turning over by itself, even though the ignition was off.
I'm guessing that there's a short circuit somewhere, or the ignition circuit or some starting-related circuit has gotten fused or stuck so that it's always on/connected.
Does anyone have any ideas?
I guess the lesson is, get the proper parts, rather than trying to use something for what it wasn't meant to do.
