  • 1994 - 1995 Specific Tech
Starting Problems
  • Thread starter Thread starter Want2GoFaster
  • Start date Start date May 6, 2004
Want2GoFaster
77
Nebraska
May 6, 2004
  • May 6, 2004
The Scenario: Pull the stang into work yesterday morning, park it, get out. I realize I'm too far into the next stall & jump back in, turn the key & I get a click-like sound like the starter is engaging the flywheel, but doesn't turn it. I try again & it fires right up.
After work, she fires right up. I stop at a Quick Shop on the way home & when I try to start it again, I get the same sound. This time I need a push to compression start it.
I notice on my way home that my battery gage is leaning towards the negative, my oil pressure gage is pegged way past the "H" and my temp hage is pegged way past the "H". The gas gage is OK. So at the stop light, I keep my revs up thinking that my alternator is going. Then, when I'm almost home, the gages go back to normal. I park it in the garage, shut it down. I try it & it fires right back up. I come back in about a couple of hours to check it and it fires up. I try it this morning & I get the "click" & it won't fire.
I know our gages are notoriously inaccurate, but does their behavior indicate the alternator going, the battery going or both?
Any help will be greatly appreciated.
millhouse
1,985
Simpsonville, SC
May 6, 2004
  • May 6, 2004
It sounds like a bad battery terminal or ground going bad to me.
C
CivicEater
579
  • May 15, 2004
Bump for you
Want2GoFaster
77
Nebraska
May 15, 2004
  • May 15, 2004
It was a bad starter/solenoid and a bad ground. Got a new starter, cleaned up & reconnected the ground problem and all seems well.
Thanks for the input!
C
CivicEater
579
  • May 15, 2004
Hey where was your ground problem becuase this sounds very similar to what I am going through.....I suspected my Starter, and I think I have a bad ground as well becuase my gauges are acting nuts and it smokes from my ebrake.....
Want2GoFaster
77
Nebraska
May 15, 2004
  • May 15, 2004
The shop said it was in the back, I'm not sure to it's exact location. It was a body ground that went to the block.
J
Engine Stalling
  • josh40tay
  • Oct 20, 2026
JD1964
T
Inside is completely dead
  • TunaCar
  • Oct 18, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 20, 2026
DadLife0724
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 26, 2026
manicmechanic007
Y
2012 GT/CS Electrical Problems
  • Yomster
  • Dec 2, 2025
2005 - 2014 S-197 Mustang -General/Talk- Dec 2, 2025
Bullitt347
2000 GT-Front Brakes Not Releasing
  • stormsedge
  • Aug 7, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 7, 2026
Bronco2fan
