Starting Problems
89notchback5.0
10
PLEASE HELP! Starting Problems
I just installed new 30lb injection with the 70mm C/L mass air meter for 30lb injectors. the car doesnt want to start unless i hold the gas pedal to the floor. i also have edlebrock intake also. thanks for any help
When you hold the gas pedal to the floor, it cuts fuel to the injectors. You are dumping too much fuel at start up, that's why it won't start without flooring it. :) This is easily fixed with a tune. They can cut down on the injector pulse width at start up.
Agreed with Nick again about too much cranking fuel. I would add that the issue should be worse when the motor is hot than when it's cold.
What kind of mods do you have?
Good luck.
