Startup Problem!
savegoodautonfg
1,085
Ok, when i start up my car for the first time like after it sits over night it will sometimes die the first time i start it unless i hit the gas. Now, its not a big deal but it is annoying sometimes and i was wondering if anyone knows what it could be?
The IAB isn't working like it should. See "Help me create the Surging Idle Checklist" at http://forums.stangnet.com/showthread.php?t=534062
for help with your idle problems. The first post contains all the updates to the fixes. I continue to update it as more people post fixes or ask questions.
Even though you may not have other idle problems, the fix is in the sticky.
savegoodautonfg said:
I have an extra IAC laying around. SO should i, just take the other one clean it and put it back on my car?
You're saying that should stop my problem?
Sometimes cleaning them does the trick, sometimes it doesn't. I would give it a try. It is definitely an IAC problem.
I am having a similar problem with my 94. Cold start surges until it warms up. I cleaned the IAC before I put it on new motor. It was summer when I swapped out motors so I didn't really get the affects of a real cold start until October. I ordered a new IAC shall be in tomorrow.
Jrichker - I thought that your surging idle checklist was a very well written start on fixing idle issues. My car had a hanging idle when coming to a stop but now that I brought my idle to basically as low as I can get it with the spout out and IAC disconnected. I had it between 590-620 with E Cam. Now it idles between 750-800 on a digital multimeter w/RPM and no hanging idle! Thanks. A valuable writeup indeed.
