Anyone with a 89 5.0 that has a pic of their starter relay SEND IT TO ME!!!!!
With a graphic description of where the wires plug in. Also, where does the MAP sensor vaccum hose plug into the TEE?? (the triple way connector on the far passenger side of the engine compartment). Where does the lower plug, plug into on the TEE?? Also, Are starter relays different from the 87 2.3 mustangs to the 89 5.0 mustangs??? I just swapped the motors and left the starter relay in but I am not sure I connected them in the right order. Are ignition switches different?? Is my fuel pump relay under the seat or under the hood??? Will the engine start without the crash sensors plugged in??? I want to leave them out when I put the front end back in. Does the wire that goes to the A/C compressor have a white connector??? My motor did no come with the compessor so I have an "extra" white plug that I assume went to the A/C compressor. I have connected everything else except the trasmission wiring, MAP sensor vaccum line, fuel lines, and the radiator (I know it wont start but I wanted to see if the motor would turn over) but when I turn the key, all I hear is a distinct "click". Is it because the starter relay is incorrect??? PLEASE HELP IF YOU HAVE THE ANSWER TO ANY OF THESE QUESTIONS!!!!!!!!!!! I LOVE MUSTANGS AND NEEDS SOME HELP!!!!!!
