stang22
MustangLX-5.0 said:I know there is only 1 wire on the front terminal.You said there are "2" wires that run from the starter.Correct,there are 2 wires than runs from the starter,on the later models.All pre- 91 models that i've seen had only 1 wire coming from the starter.And in either case,only 1 of them goes to the front relay terminal.The older models dont have that smaller wire coming from the starter.Least not the ones i've seen.Maybe it's a difference on automatic transmissions.Because the '89 I owned was a 5 spd and the '92 is an Auto.Or maybe like I said it is because I have a factory alarm wired.Maybe the second wire is a starter kill relay or something.I am not certain.
The reason all of this is so fresh is because I just hide my wires and had to reconnect my solenoid. I got some tips from ALMOST STOCK and I am almost certain that he has the same wires running from his starter and his in an 1989. No biggy though, as long as they get thier problems worked out.
Tim
EDIT: ALMOST STOCK may have a mini torque starter, this may be why. Good information to know the difference though.
THIS POST IS MAKING ME DIZZY.
