looks like it is coming from the rearmain seal... gonna look at it tomorrow but i think it could be the rearmain seal how hard is it to change the rearmain seal??
I would hold off till you get to see what gives before worrying. Valve cover leaks, etc can leak down the back of the block and appear to be a RMS leak.
Also, Excessive crankcase pressure can take the path of least resistance if you have a clogged system, and that can force oil out past the crank seals.
I would clean it all up real well and then safely let the car idle and note the source of new leaks.
