has anyone done this ,i have a bad coffee stain i wanna get out ,can i do it and just leave the door/windows open all day?,any help would be appriciated,thanks
OK, I clean up and sell cars once in a while for extra cash. I get the rattiest looking interiors, clean um up and people say "oh it's so clean inside". Here is the trick for BAD CARPET: take it out, take a spray bottle of (household) carpet cleaner, spray the thing down good. Put it in the back of a truck and head to the local car wash. I throw them on the ground, spray them, rinse, and there ya go. I have the luck of having a heated inside garage to let them dry in. It won't hurt a thing. PS they weigh a ton wet.blueflamedlx said:has anyone done this ,i have a bad coffee stain i wanna get out ,can i do it and just leave the door/windows open all day?,any help would be appriciated,thanks![]()
blueflamedlx said:the car just got a cage and i allready put the carpet back in and don't really feel like taking it out again,anyone else steam cleaned their's?
88LX said:Castrol has this cleaner thats cool. i think its called Super Clean. my friend spilled a mocha chiller, i think thats some coffee thing, and with a little scrub it took it right out. cant even tell it was there. i diluted it though because i guess its pretty strong stuff.
PonyBoy90 said:I'd try the shampoo'er first before you spend all that time and money swapping out the rug.
I've done many of my families cars with a grocery store rented easy-off shampoo machine. I get the smaller one with the attachment for upholstery and do both the seats and the carpets.
As the carpet is polyester fibre, I'd say the shampoo'er should get out 90% of the stain. The only stains you may have some difficulty with are greasy stains. Although you may not be able to get these out 100%, you should be able to reduce it greatly. Stains such as Coke-Cola, coffee, dirt, mud, etc should come out 100%.
If your carpet is discoloured, it won't help that. The instructions on the back of the bottle of the soap solution will state that the soap may lift/discolour your carpet some but this all depends on how strong/concentrated you make your mix. My advise, use the concentration they advise on the bottle and make sure the water is hot. Not too hot though. DON'T USING BOILING WATER.
24 hour rentals cost about $25. Go to CT and buy your soap there. They've got a way better selection and I don't like the Easy Off line much. Get a Bissell soap. I used one with a lemony smell and it worked great and didn't discolour my interior (Mine titanium by the way circa 1990).
Don't soak the rug! Use in moderation and everytime you sweep the carpet clean, then decide if it needs some more. Upon sucking up the water and suds, press firmly down on the attachment. This will maximize water reduction left in the carpet and minimize drying time.
I don't usually advise doing this in the winter or spring as it's cold and wet. Summer is the best as on a nice hot day it'll dry within an hour. If you have to, do it in a garage and leave your windows open over night to air out.
Once dry, dry vacuum out the carpets to remove any residue soap and scum.
Have fun![]()
