Steeda Bump Steer Kit Worth it?
WhiteDevil
2,717
San Diego
Well as im planning out my work this summer i will be doing a lot of updating on my front suspension. Right now i have Mach 1 Tokicos, steeda springs, and MM Caster Cambers. I will be doing 03 cobra A-Arms and new Urethane bushings throughout the front. I will also be doing new inner and outer tie rods. Should i do the steeda bumps steer kit? Which one does it replace the inner or outer tie rod end? And does it replace the whole thing? Thanks guys.
I have a UPR bumpsteer kit and it's the same as Steeda's (Made by the same company). It replaces the outer tierod. It is a must for lowered cars. With the updates your doing it would work great. I would also get MM Front Swaybar Endlink Set and Front Swaybar Bushings.
