  • SN95 4.6L Mustang Tech
Steeda pullies
  • Thread starter Thread starter Lostcause
  • Start date Start date Jun 3, 2004
1 of 2 Next Last
Lostcause
81
Homestead Fla.
Jun 3, 2004
  • Jun 3, 2004
I'm stuck the crank pulley would not come off. Does any one have any tips one on how to take the crank pulley off. Can you use the stock belt our do you have to change the stock belt the belt would not fit with just the alt. and water pump pullies? Any help would be help full thanks.
Aaron 4.6
2,695
Georgia
Jun 3, 2004
  • Jun 3, 2004
Need more detail when you ask for help. Is the crank bolt out or in? Are you having a problem with the balancer puller? Give us a little more info to deal with.
Lostcause
81
Homestead Fla.
Jun 3, 2004
  • Jun 3, 2004
The crank could not be removed it will tommorow is there any tricks to help break it loose? It was a PITA and me and a friend could not move it we are going to try agian but it would not move a bit. Any advice we don't have air tools available.
Aaron 4.6
2,695
Georgia
Jun 3, 2004
  • Jun 3, 2004
I want to help, but you are still too vague. Is your problem with the BOLT or the BALANCER? Those are two different problems. If the bolt won't break loose, say so. If the bolt is out, but the puller won't break the balancer loose, say so.
I don't know what that means.
J
jbrown
393
Tallahassee, FL
Jun 3, 2004
  • Jun 3, 2004
I think you need an impact wrench to change the pulleys.
03gtmustang
923
Northern Va
Jun 3, 2004
  • Jun 3, 2004
Yes you need a GOOD impact wrench to change out pulleys, also put your car in 5th gear when your taking them out. After you put on the steeda's you DO NOT need a new belt, your stock one is fine.
Lostcause
81
Homestead Fla.
Jun 3, 2004
  • Jun 3, 2004
The bolt will not break loose at all for now that is what I mean. the alt. and water pump pulleys are on just that the bolt(crank) will not move.
Aaron 4.6
2,695
Georgia
Jun 3, 2004
  • Jun 3, 2004
Gotcha. Step 1 would be to put the rear wheels on the ground, drop the transmission into 5th, and seeing if that amount of friction in the drivetrain prevents the motor from turning. Step 2 would be bolting a piece of scrap metal (a 12-18 inch piece of flatbar works) to the pulley using two of the balancer puller bolts and then bracing the bar against something solid (some blocks on the floor work great). That will keep the pulley from moving. Step 3 is either invest in an impact or get a shop to do this for you.
Hope one of those options is feasible.
EDIT- You CANNOT do this with just a ratchet. You should have AT LEAST a 1/2" breaker bar with a foot and a half of handle, and I have needed a 2 foot extension to get that sucker free before.
03gtmustang
923
Northern Va
Jun 3, 2004
  • Jun 3, 2004
You need an impact wrench, theres no other way to get it off.
W
wytstang
Mustang Master
Mar 14, 2004
4,988
Summerville,SC missing South Fl. weather :(
Jun 3, 2004
#10
  • Jun 3, 2004
  • #10
I'm helping him do the pullies. Do you think a breaker bar would do the trick?
Cobra Jay
889
Motor City
Jun 3, 2004
#11
  • Jun 3, 2004
  • #11
What he said!
03gtmustang
923
Northern Va
Jun 3, 2004
#12
  • Jun 3, 2004
  • #12
Nope, but maybe if it was like 50ft long.
W
wytstang
Mustang Master
Mar 14, 2004
4,988
Jun 3, 2004
#13
  • Jun 3, 2004
  • #13
DAMN , DAMN , DAMN
mdvaldosta
72
#14
  • Jun 3, 2004
  • #14
no you dont need an impact wrench to get the pulley if on a 5sp. A breaker bar works fine, or double wrench the bolt. Ive got air tools and I didnt even use them. Just put it in 5th like they said and crank down on that sucker. Just did some steeda pulleys this way a few days ago.
W
wytstang
Mustang Master
Mar 14, 2004
4,988
Jun 3, 2004
#15
  • Jun 3, 2004
  • #15
You have given us some hope! We'll find out tommorow when we try a breaker bar if not then one way or another it will come off wether it be by muscle our air shes coming off.
02mingreyGT
280
Portales, NM
Jun 4, 2004
#16
  • Jun 4, 2004
  • #16
Well whatever you do please god dont snap that bolt off in the crank or else your problems will be MUCH more serious........kinda like MINE CLICK HERE!!
C
CottonBurnerz
Banned
May 10, 2003
1,554
Drink and Drive = Teh Lose
Jun 5, 2004
#17
  • Jun 5, 2004
  • #17
Just ordered mine just now.. I hope I can do with with my 1.5 foot breaker bar..
I've also read something about going to autozone and let them remove the bolt for you for free?
Modular2v
3,222
23
99
oklahoma
Jun 5, 2004
#18
  • Jun 5, 2004
  • #18
you need a puller it took me about 10 minutes to do mine, Make sure you puts some silicon on the key or you will have an oil leak
C
CottonBurnerz
Banned
May 10, 2003
1,554
Jun 5, 2004
#19
  • Jun 5, 2004
  • #19
Thanks for the heads up.. Anything else I should look out for? RTV sealant silicone will work fine right? I have the black version..
KaPPaBaLL
1,326
BAYAREA
Jun 5, 2004
#20
  • Jun 5, 2004
  • #20
whichever is hi temp
1 of 2 Next Last
Engine Belt routing with supercharger and smog/ac/ps delete
  • Steve6482
  • Jul 15, 2026
Fox 5.0 Mustang Tech Jul 15, 2026
Steve6482
Idler pulley as substitute for Power Steering Pump ?
  • Bhenders
  • Jul 15, 2026
  • Other Auto Tech
Other Auto Tech Jul 16, 2026
LILCBRA
Engine My Gates K060845 (85 1/4”) belt doesn’t fit
  • Mcmahst
  • Jun 26, 2025
Fox 5.0 Mustang Tech Jun 27, 2025
Mcmahst
For Sale Vortech crank and blower pulleys
  • Dontknowchit
  • Sep 25, 2025
  • Engine and Power Adder
Engine and Power Adder Oct 15, 2025
Dontknowchit
D
Loud noise(s) from Engine Bay
  • DuluthFoxbody
  • Oct 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Thursday at 3:50 PM
AeroCoupe
