- Apr 8, 2002
- 58
- 0
- 0
StangSuspension.com is now carrying the new Steeda Tri-ax Shifter for the Shelby GT500. This shifter is specifically designed to fit the 2007+ Shelby's transmission.
Steeda Part # 555-7307
Often imitated but never truly duplicated, get the original and best line of short throw shifters for your Mustang! Steeda's Tri-Ax® Shifters! Like the tens of thousands of Tri-Ax shifters that came before it, this Tri-Ax carries over many of the same great features like an extremely short throw, precise action, our two-position handle height, and internal spring tension to assist you in never missing 3rd gear! This last feature is exclusive to the Steeda Tri-Ax for current Mustangs and not found in any other shifter! The factory steel mounting rail is replaced with a substantial billet beam for more positive location; and upgraded bushings are supplied to further reduce deflection under hard shifting. Urethane bushings are included for less defection and a more positive feel. The Shifter base, top plate and beam are all CNC machined by Steeda from Billet 6061 Aluminum.
Benefits:
Visit http://www.stangsuspension.com/store/comersus_viewitem.asp?idproduct=1260 to order Today.
STANGNET MEMBERS RECEIVE 5% OFF BY USING THE DISCOUNT CODE STANGNET UPON CHECKOUT
Benefits:
- Superior, patented Steeda technology!
- Internal spring tension, not found in ANY other shifter!
- Complete billet design from 6061 aluminum, made in the USA in house at Steeda!
- Never miss 3rd gear again!
